Thread: Y30DT boost sensor?
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Default Y30DT boost sensor?
    Ok guys, where do I find it just to clean it for the hell of it?
    If someone could indicate on the photo in this post it would be appreciated http://vectra-c.com/forum/showpost.p...6&postcount=11
    First question, why do you want to clean it?
    I can understand wanting to know where it is, so that if the MAP sensor fault is returned it is easy to locate and diagnose
    See number 8
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    The turbo sensor is mounted just above the turbo. But I though the map sensor was in charge of boost?
    Why do you want to clean it?
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Quote Originally Posted by Critch View Post
    Just curious to see if it's dirty, sticky or whatever. Same reason as I'd like to do the MAP sensor and EGR when I'm bored .
    So the boost sensor is the same as the turbo actuator or turbo sensor?
    Basic location on that pic is near the yellow bit at the back right , underneath the black pipe that has heat shield on it where it goes over the top of the turbo
    The big give away when you find it will be the words boost sensor written on it lol
    Sent from my iPhone using My thumb
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Fair enough.
    The MAP sensor is in control of how much boost I thought?
    There is a sensor on the turbo actuator But I as under the impression it was there just to control the action of the waste gate
    I found this picture
    It is for a Z30DT, but the part looks almost identical on the Y30DT :
    http://data.motor-talk.de/data/galle...8549159808.JPG
    http://data.motor-talk.de/data/galle...0108909623.JPG
    Celes uploaded this some time ago, shows the position on the Y30DT :
    http://data.motor-talk.de/data/galle...6458945544.jpg
    Put the two together and you should be able to find it
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    That is labeled on the pics I uploaded in the info thread.second pic listed as MAP sensor
    Just not a very clear pic.
    Once I'm on the comp I'll upload that into the thread. Unless one of you 2 can do it?
  1. Y30DT - so is this the turbo actuator (boost sensor)?
    By gtr1000 in forum Y & Z30DT Specific
    Last Post: 2nd January 2012, 12:29
  2. Y30DT - what's this sensor?
    Last Post: 1st January 2012, 18:59
  3. Y30DT - so is this the MAP sensor?
    Last Post: 1st January 2012, 18:58
  4. Y30DT Looses boost, clear fault code and back to normal!
    By tommychimp in forum Y & Z30DT Specific
    Last Post: 5th September 2011, 20:07
y30dt
y30dt boost sensor
Z30dt boost sensor pipevectra c turbo boost sensory30dt turbo pressure sensorz30dt boost sensorinsignia 2012 sensore mapy30dt turbo boost sensory30dt egrz30dt enginey30dt engine for saleEGR Y30DT
