Results 1 to 10 of 14
Thread: P0234 Error,Remapped Signum 2.8 Turbo
    Regular Member viper8's Avatar
    Mar 2011
    Northamptonshire
    Default P0234 Error,Remapped Signum 2.8 Turbo
    hello guys
    been getting the P0234 error
    ( boost pressure control circuit positive deviation ) present
    have looked at boost pipes and intercooler pipes ,no splits
    and also cleaned boost sensor ( was clean )
    car keeps going into limp mode when accelerating hard .
    it clears when you restart the engine
    but the car seems very slow and slugish
    any ideas anyone
    Administrator plasma's Avatar
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    think soulman had this problem with his when remapped, turns out they needed to sort the mapping out a bit...
    How long ago was it remapped and was it doing it before remapped?
    VOTING UKIP IN AVELEY
    20 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    nope not the Case Dean ....
    mine was running fine but was getting EML on ...
    Mar 2011
    Northamptonshire
    well when it was remapped i had loads of problems with it and the guy was out all the time to redo it ..
    turns out it was the fuel .the muppet did not tell me to use super unleaded fuel .
    i put shell v power in one day
    and it went like a rocket and no limp mode or errors
    boosting perfect
    now a couple of months later i get this error and limp mode
    read another thread on here that it is underboost .
    Mar 2011
    Northamptonshire
    20 Post(s)
    Vehicle : Vauxhall
    Engine : 1.9cdti
    Year : 07
    he was running a deisel tho ...........
    I would get hold of your mapper again and get him to have a look ....
    Mar 2011
    Northamptonshire
    yes .i just noticed that it was the same problem
    the mapper does not do it anymore
    WGAF#5
    What plugs are you running ?? I'm aware of s e of the owner on vxronline having the same fault and having replaced the boost pressure sensor then had to have their plugs re gapped
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    Do you have the auto? Is it a possibility it could be the box? I had new plugs when I had mine remapped and no problems as thats what is advised... may well be the case - I also went for Denso iridium ones for Turbo performance engines which were set differently to the normal ones...
    Mar 2011
    Northamptonshire
    Deztroyer
    i have not got a clue what the plugs are in the car
    what would you advise putting in
    have you a link to the thread
  1. P0234 Error Code Definition
    By viper8 in forum Engine & Drivetrain
    Last Post: 31st December 2011, 14:10
  2. P0234 Error code.
    By ectraz in forum Electrical & ICE (including SatNav)
    Last Post: 23rd September 2011, 20:23
  3. error code P0234 - Boost pressure control
    By duncanm in forum Engine & Drivetrain
    Last Post: 4th May 2011, 17:24
  4. Replies: 6
    Last Post: 3rd September 2009, 16:40
