Results 1 to 10 of 20
Thread: Goodyear to rename tyres
    Default Goodyear to rename tyres
    A heads up for those people that continue to use and fit Goodyear tyres
    As we all know the Vectra C was offered with Goodyear tyres and the NCT5 was fitted as standard
    Many people changed to the GS-D3
    A new assymetic tyre was also introduced (inspringly called Assymetric) and many people swapped to this as the GS-D3 was withdrawn
    Earlier this year this too was replaced by an updated version, the Assymetric 2
    From 2012 the NCT5 (tread pattern) and Assymetric 2 will be withdrawn, both being replaced by a new NCT5
    So if buying Goodyears tyres next year be well aware of this change, and make sure you are NOT sold old stock with the old tread pattern
    Stock code is NCT512
    A simple solution would have been to be call it something else...
    Prsumably they did this to make it easier for those already using the NCT5 and keep existing customers
    Ironically, I tried to stick with Goodyear tyres as the Michelin tyres I wanted were not available for the Vectra C (well they were but about 50% more expensive)
    After testing the latest Michelin tyre earlier this year I now have new Michelin tyres on my car, the retail price was revised in November, and the final public release tyre (Michelin Pilot Primacy 3) has a tread pattern almost identical to the latest NCT5
    Full Member Big-Pete's Avatar
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    Moved
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    I'll bear that in mind. Mine had the NCT's on it as purcahsed, I was one of the ones had no problems with them at all, drove fine through two winters. On Neutons now so won't be requiring new anytime soon.
    Quote Originally Posted by Grumpy1954 View Post
    Me too, I went through one entire set of the NCT5 without any issues
    However it was the price, at £150 per tyre (as it was then)
    Good to see the NCT5 (2012) is going to be launched at £85 to £90 (not fitted)
    WGAF#5
    Easiest way if telling the date on a tyre is the date stamp in a rectangle is a four digit code
    For example 2012 would have been manufactured in the 20th week of 2012 and 5011 would have been made in the 50th week of 2011
    Hath when your looking at the tyres our buying ..is also an easy way of seeing how old the impress stock is at the garage your buying from
    Quote Originally Posted by Deztroyer View Post
    It's not always a rectangle, on the Michelin it is in an oval
    Not much good during the ordering process
    As above you could end up with the old tread pattern or the new NCT5 if you simply ask for Goodyear NCT5
    Then arrive at the premises and find it is this years version
    As above, they really should have given this new tread pattern a different name!
    A big clue should be the difference in price, but some outlets may revise the price of the old tread pattern to clear old stock
    Regular Member DeJohnny's Avatar
    Jun 2011
    belgium
    Like said above, nct5 was fitted on delivery, but not very happy about them! When raining almost no grip, now using contisportcontact3 as summertyres
    Regular Member Jow20's Avatar
    Sep 2010
    Leeds
    Mite get the old tread pattern cheaper now!!! If so who cares, happy days.
    11 Post(s)
    Even simpler for the customer is to not buy NCT5's ever again.
    The original ones were ditch finders, what's to say the new ones aren't any better?
    Look at it another way, having once owned an Allegro, I wouldn't want another one knowing how crap they are.
    scottish region
    Sales are down so names changing to bad year
  1. goodyear tyres
    By PAULMAC77 in forum Vectra C / Signum Car Chat
    Last Post: 16th September 2008, 16:20
  2. Goodyear tyres
    By caledonia in forum Vectra C / Signum Car Chat
    Last Post: 16th September 2008, 00:27
  3. Goodyear tyres
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 15th August 2007, 21:21
