Thread: Engine Rattle on start up
    Regular Member Mark2.2's Avatar
    Feb 2006
    North East Uk
    Default Engine Rattle on start up
    When the chain is on its way on the Z20NET what are the signs? My car has a rattle on it every time it's started up, even if it's warm. When the engine is running its fine, no noise. The noise on mine is only on starting it up for about 2 seconds then it's gone. Should I be worried? My car is a 2007 model Z20NET with 57k on the clock. I have had a pre face lift sri turbo before and it never sounded like this one. Thanks for
    any info. What's the price on a new timing chain fitted these days?
    Sent from my iPhone using Tapatalk
    Regular Member benholden2010's Avatar
    Oct 2010
    middlesbrough
    As I said before fella, the rattle on start up is the sign the chains not very well, or the tensioners nackered. I did mine for about £180 all in, but that was just parts with trade club discount. Was worth it though as it's piece of mind and she's quite as a mouse now.
    Remember you saying you had done chains before? If so you will be able to do this piece of cake, it's easier and cheaper than fitting a new engine anyway
    Feb 2006
    North East Uk
    True, I intend to get it done as soon as I can, I just worry about it all the time. What are the tell tale signs of the chain on its way out, do they rattle on idle as well? Thanks
    Oct 2010
    middlesbrough
    If it's really slack it will rattle on idle, mine only rattled slightly on idle, yet when I replaced it they was about an inch play. Worthwhile getting it done though mate, both chains aswell not just timing chain
  1. rattle on start up
    By VEC-MAN in forum Vectra C / Signum Car Chat
    Last Post: 8th May 2012, 22:16
  2. Rattle on start up
    By Vectracdti150 in forum Vectra C / Signum Troubleshooting
    Last Post: 24th February 2011, 23:34
  3. rattle on start up
    By ant6566 in forum Engine & Drivetrain
    Last Post: 11th April 2010, 19:05
  4. engine rattle on start up
    By craigyboy in forum Engine & Drivetrain
    Last Post: 13th October 2009, 19:35
  5. 1.8 vvt - engine rattle on start up
    By Misty Design in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2008, 09:42
