Results 1 to 3 of 3
Thread: 1.9CDTi 8v 120hp Cylinder Head Replacement
    Regular Member cphaza's Avatar
    Hertfordshire
    Default 1.9CDTi 8v 120hp Cylinder Head Replacement
    Bonjourno chaps
    I'm about to start rebuilding my engine again after water pump seizure. Needed 5 new valves in the end, two new buckets, three helicoils for the glow plugs holes, a load of shimming and a skim.... Anyway, i was wondering if anyone has any suggestions of any 'special' things to do while its all apart? I am going to do the EGR cleaning job as described on this site while its off, boost sensor too. May as well change cam shaft sensor while its in front of me. Anyone with any other suggestions?
    Chris
    Regular Member C-Owner's Avatar
    May 2011
    South London
    If you have any spare shims left over I'll have them
    Other than that looks like you have covered everything else, unless you fancy doing a DPF knock through and remap !!!!
    Hertfordshire
    certainly an idea. can you disable them with tech2/reprogram the cim with a program from a non dpf car? Is is it more complicated than that?
  1. Cylinder head
    By GCusdin in forum Engine & Drivetrain
    Last Post: 20th September 2012, 11:11
  2. is my Cylinder Head going
    By jinkie in forum Engine & Drivetrain
    Last Post: 4th January 2012, 09:25
  3. 1.9cdti 120hp REAL engine code?
    By cphaza in forum Engine & Drivetrain
    Last Post: 22nd November 2011, 15:51
  4. Cylinder Head
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2008, 15:35
if I replaced my cylinder head on my 1.9 cdti engine do I need to code it
