Results 1 to 10 of 14
Thread: Anyone had this happen???
    Dec 2011
    ESSEX
    Default Anyone had this happen???
    got a deseil 16V 2L cdti engine. You can travel along for miles and no problem, all of a sudden the car just cuts out, exactly like I have turned off the key.
    HOW do these fuel pumps work; Do they have a cut off valve somewhere on the fuel pump, or does it stop via an electrical sensor connected to the ECU?
    Once it stops, wait 30 secs then it drives again and starts perfect. This fault is so intermittant its hard to trace. But it just stops and seems like the fuel shut off valve (if its got one) has been closed.
    Any help pleasssssssssseeeeeeeeeeeeeee.
    Many thanks.
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    what engine do you have, is it a 1.9 cdti or a 2.0 dti?
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    What steve said if it's a 2.0 16v diesel it's a dti if it's a 1.9 16v it's a cdti 150
    Dec 2011
    ESSEX
    Its a 2L y20dth estate
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    It's a high-pressure fuel pump on tue side of the engine mate they have vein known to break and cost over a grand to fix i don't think it's mechanical it's the electronics that breaks I think
    Trim : Sport
    Engine : Petrol
    2.0 Ltr DTI as I suspected. Hmmm Intresting I had the same problem with my 2.2 DTI (Its fixed now) It would run fine and then just cut out.
    have you noticed and hics/hesitation when accelerating?
    does your car have a TPS (throttle position sensor, a small black plastic box next to the boost sensor?) on your upper inlet manifold (throttle body). some do and some don't.
    Dec 2011
    ESSEX
    Im not sure DTI-STEVE. I can have a look tomorrow in daylight.
    What was your symptoms and what was the repair? many thanks
    Quote Originally Posted by FALLEN_ANGEL View Post
    From the symptoms it is not the fuel cut off valve
    Once that has activated it has to be replaced (similar to an air bag, once used destroyed)
    Take the car to a diesel fuel pump specialist for diagnostic check
    Should cost you about £40 and takes about 20 minutes
    If the fuel pump has indeed failed the issue will get worse over the next 1000 miles and will eventually seize
    As above, prepare to part with £1000 plus
    Quote Originally Posted by DTI-Steve View Post
    does your car have a TPS (throttle position sensor, a small black plastic box next to the boost sensor)?
    If the TPS has failed the car should lose power and then idle only
    Having the engine switch off during normal driving is quite extreme
    Dec 2011
    ESSEX
    well its just happy to plod along, no warning, no hesiatation just as fast as a bomb, it just turnes itsself off. no warning lights no ecu fault codes. How does the car stop running, i.e is their an air flap or a stop solinoid. I need to find out the engine stops once you turn off the keys, ????
  1. what will happen to my sat nav?
    By stanny in forum Electrical & ICE (including SatNav)
    Last Post: 23rd June 2010, 17:45
  2. This could happen to you
    By Tadpole in forum Comedy & Humour
    Last Post: 28th November 2009, 22:09
  3. It could happen
    By silverhairedracer in forum Comedy & Humour
    Last Post: 21st November 2009, 12:51
  4. What would happen...?
    By larrysSRI in forum Engine & Drivetrain
    Last Post: 13th November 2009, 18:22
  5. It had to Happen
    By KC in forum Comedy & Humour
    Last Post: 19th June 2009, 08:28
