Thread: Crunching noise +ARB bushes
    Regular Member FrenchConnection67's Avatar
    Dec 2011
    Liverpool
    Default Crunching noise +ARB bushes
    Hi everyone,
    There is a horrible crunching noise coming from the front of my vectra when I take bumps and today, when I checked the ARB bushes there seems ok although you cant really tell like this. There is no free play in the ARB link rod ball joint neither.
    I would like to change them anyway as it's apparently the most common reason for this crunching noise. There is not much space to access the bolt though and wonder whether its possible to replace them without dropping the the subframe?
    i checked the driveshafts and there is a free play in both the left and right one, do you think the noise could come from this rather than the ARB bushes?
    Also, can anybody tell me what size are the bushes i have got installed on the car, I couldnt see completely the ref number so i only noted the last 6 digit: Front ****131232; Rear ****457385.
    wirral
    39 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    I'd deffo say the noise is arb bushes mate.
    And at about a fiver for the pair it's worth changing anyway to be sure.
    I don't think play in drive shafts will do it tbh
    Play would probably give you vibrations during acceleration
    Dec 2011
    Liverpool
    Quote Originally Posted by Critch View Post
    Thanks mate, do you know if you can change them without dropping the subframe?
    Regular Member cossie's Avatar
    MANCHESTER
    Just done mine - there is a how to in the how 2 section. Tight, but can be done without dropping the subframe with a bit of patience.
    see http://www.vectra-c.com/forum/showthread.php?t=72828
    Cossie
    East Midlands
    See THIS thread mate,take your time and have a good read,all the info you need is in there
    Dec 2011
    Liverpool
    Thanks a lot guys, much appreciated. Just ordered the 10mm ratchet spanner for the job and will go to my dealer for the bushes tmrw.
    Dec 2011
    Liverpool
    Do you think i need to change the ARB link rod too, even though there is no free play at their ball joint?
    East Midlands
    Quote Originally Posted by FrenchConnection67 View Post
    Fit the bushes first ,see how you go,they are easy to change should the need arise.
    Dec 2011
    Liverpool
    ur right macdad, I am gonna change the bushes first n see how it goes.
    Thanks to all who advised me tonight
    Ill keep u posted
  1. Crunching noise on bumps
    By crazychemist76 in forum Suspension, Wheels & Brakes
    Last Post: 26th February 2013, 09:11
  2. Replies: 5
    Last Post: 25th June 2012, 15:40
  3. crunching noise under braking
    By drspamuk in forum Handling & Braking
    Last Post: 3rd October 2010, 16:50
  4. Crunching Noise
    By Decker in forum Suspension, Wheels & Brakes
    Last Post: 21st February 2010, 01:31
  5. Crunching noise
    By Silver Vectra C in forum Vectra C / Signum Car Chat
    Last Post: 28th February 2007, 21:55
