Thread: Oily air filter!
    peterlee
    Vehicle : 2.0t
    Trim : sri
    Engine : 2.0t
    Mileage : 161000
    Default Oily air filter!
    Just checked my pipercross panel filter today and its covered in greasy oil?!does anyone know how and why this cud be?car is a 2.0 dti 52 plate.thanks
    Engine : 1.9 CDTi
    Did you fit the filter as I think they are 'oiled' when you fit them.
    peterlee
    Vehicle : 2.0t
    Trim : sri
    Engine : 2.0t
    Mileage : 161000
    Yes i fit it but this is black minging oil lee mate
    wirral
    49 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    All the crud from the air mixing with the filter oil
    Just give it a clean an re oil
    peterlee
    Vehicle : 2.0t
    Trim : sri
    Engine : 2.0t
    Mileage : 161000
    Ok mate.thanks.
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    Hate to say it, but it could also be the oil seals in your turbo gone, so the turbo might be spraying oil into the inlet manifold.
    The turbo has an oil feed from the oil pump.
    The, not very good, photo shows the clean air end of the turbo removed and oil sprayed over the clean air inlet.
    It is not that difficult to check, but it does mean removing the clean air end of the turbo.
    The 2nd photo shows the dirty end of the turbo before cleaning.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by TonyP2020 View Post
    Any oil at the turbo isn't going to affect the air filter m8. Even if there is oil at the turbo that can be normal due to the oil breather.
    For the OP chances are the oil layer - which is typically on these filters - has mixed with the crap which comes into the airbox with the intake air. The reason I didn't keep my performance filter on was fear that the oil broke off and damaged the MAF sensor.
    You could also check the air filter outlet pipe, to see if there is oil residue, whilst replacing / cleaning the air filter
    I have also noted that pipercross advise to use an air filter cleaning kit, yet they don't seem to sell them on their website, to be used after "machine washing" their air filter to refresh the oil
    The reason the oil looks awful is due to it attracting and extracting all the particulates and is now no longer able to hold them in suspension
    Analogy :
    Cover someone in treacle then throw feathers over them
    Eventually you will have thrown on so many feathers the excess falls to the floor
    peterlee
    Vehicle : 2.0t
    Trim : sri
    Engine : 2.0t
    Mileage : 161000
    So do you alm think it would be better to just put a standard paper filter in?the airbox is de-restricted so shouldnt make adifference would it guys,?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by dazza2393 View Post
    Yip I went back to the standard filter after 10days.
  1. blanked egr but swirl bar looking oily again
    By monty2000 in forum Engine & Drivetrain
    Last Post: 1st February 2013, 17:26
  2. Oily smell inside cabin when stopping on lights/junctions/roundabouts
    By crism in forum Vectra C / Signum Troubleshooting
    Last Post: 19th July 2011, 07:46
  3. changin oil, oil filter air filter and plugs any handy tips!!
    By wallace78 in forum Engine & Drivetrain
    Last Post: 5th February 2011, 15:04
  4. oily air intake
    By Graeme01 in forum Engine & Drivetrain
    Last Post: 14th January 2010, 04:09
  5. Oily stuff!
    By SWIPER in forum Vectra C / Signum Car Chat
    Last Post: 3rd January 2009, 14:55
insignia air filter pipe oily
