Thread: Help please engine will not rev
    Kingston Upon Hull
    Default Help please engine will not rev
    Hi all i have a 19 sri 150
    When driving today it stoped revving i was driving at about 30mph and it would not accelerate for a few seconds then was ok for the rest of my journey home
    This happened a few months ago too
    Can anyone point me in the right direction to what it will be making it do this
    Jacko
    Kingston Upon Hull
    From reading though the forum i have found it could be
    1 EGR valve
    2 Vacuum pipes from vacuum motor
    3 a broken solder in the throttle valve motor
    is there any other thing it could be
    thanks jacko
    Kingston Upon Hull
    bump
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Give the Vacuum pipes a check first then check the throttle body sounds to me like it's one of those two, and I wouldn't be surprised if ultimately it is the throttle body solder joints.
    Engine : 1.9 CDTi
    9 times out of 10 its the egr.
    Have you done a code read or cleaned the egr?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by lee gsi View Post
    Vacuum pipes are easliy inspected with the eye.
  1. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  2. Can I replace a Z19DT engine with a Z19DTH engine, fairly easily?
    By Krusty3380 in forum Engine & Drivetrain
    Last Post: 13th August 2012, 15:24
  3. Replies: 35
    Last Post: 5th May 2012, 15:32
  4. Yellow engine light staying on & engine getting hot.
    By Phil Campbell in forum Engine & Drivetrain
    Last Post: 20th March 2010, 08:56
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
