Thread: Diagnostics scanner
    bristol
    Default Diagnostics scanner
    Hi All.
    First of all, I hope you all had a lovely Christmas.
    I have a Vectra C Design 120BHP. (2007)
    Lately I had the spanner light come on and the car went into lump mode. After I re started the car it was fine. Last night the Exhaust emmisions light came on, and the car just died on me whilst driving, almost like the diesel supply was cut. Restarted the car, and all went fine, however the light is still on.
    I now have a Maxiscan MS509 OBD2/EOBD reader, however when I plug it in the scanner is saying that the car is not communicating. Can anyone please advise if I am doing something wrong?
    Regards
    Regular Member disco dan's Avatar
    Apr 2011
    Southport
    does the pedal test work?
    Regular Member J's Turbo's Avatar
    Sep 2011
    luton
    Quote Originally Posted by icecube10111 View Post
    Hi All.
    Regards
    Are you leaving the ignition on?
    bristol
    Hi.
    Have tried the pedal trick, and my car does not seem to flash anything on the dasboard.
    Here is what I did with the scanner.
    1) Plug it in the plug underneath the ashtray (I asumed this is the correct plug)
    2) Turn on ignition, so that all lights come on.
    3) Start diagnostics on the scanner, and the scanner stops halfway, saying there is a problem with the connection.
    Am I using the correct plug?
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    What communication protocol is the reader set to?
    bristol
    Not sure.
    I dont think you can set the protocol, because when you plug it in and ask for it to diagnose, it seems like it is running trough all the protocols that it knows, but doesnt seem to have one that this Vectra model is programmed to.
    Im beginning to think that the Maxiscan MS509 does not have the required protocol installed? I might be wrong.
    Do you by any chance know what the protocol for this model would be, and if there are any recomended software that I can get for my laptop to read it with.
    Thanks in advance
    West
    maybe the lead is faulty... my ms509 connects and reads my 06 cdti 16v no bother
    bristol
    That is my thought as well at this stage to be honest.
    However I have been doing some research, and found that apparantly the newer model cars comes out with a CAN-BUS protocol. And that you need to have a scanner that is able to read this protocol. That still leaves me in the dark because.
    1) I am not sure that my car would have come out with this protocol it being only one year younger than yours.
    2) I am not sure if the MS509 can read CAN-BUS protocols or not.
    I found a scanner on e-bay that will read all protocol including the "latest" CAN protocol. I will order now, and if it works will deffinitly share the outcome, that might be usefull for any other 2007 Vectra owners.
    In the mean time if anyone can confirm the protocol I will appreciate.
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Your scanner will do canbus
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Plug scanner in
    Turn on scanner
    Turn on ignition when scanner prompts
  1. Diagnostics
    By rmg1 in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2012, 03:08
  2. Diagnostics
    By neill in forum North West (RO - Paulvectrac, ARO bonehead)
    Last Post: 10th April 2012, 19:55
  3. Rac Diagnostics Scanner
    By Paulrushton in forum Troubleshooting
    Last Post: 26th July 2010, 11:41
  4. Code Reader / Diagnostics Scanner
    By r.bailey63 in forum North East RO Vacant - ARO - Vacant
    Last Post: 4th March 2010, 10:34
