Thread: brakes
    Jul 2011
    UK
    Year : 06
    Default brakes
    Are they ment to make a noise not Swedish like a faint grind hard to describe or are they ment to be silent
    Regular Member disco dan's Avatar
    Apr 2011
    Southport
    mine are noisy first thing in the mornin.
    Edinburgh
    Could be a bit of surface rust when you first set out should clear after a couple of uses.
    Could also be wear indicator on pads. Check how much pad is left. Or could be a bit of grit trapped between pad and disk.
    Sent from my iPhone 4S using Tapatalk
    Regular Member jimmywhu's Avatar
    Sep 2011
    essex
    i had this probleam when i broke like a grinding noise from the front took it in to kia and the prob was my front disk over lapping on the brakes if that makes sense
    Regular Member benholden2010's Avatar
    Oct 2010
    middlesbrough
    I've got this coming from the front and back, thing is pads and discs are like new, it's deffernatly louder in the morning but still noticeable throughout the day, think it's just normal tbh
    Sep 2011
    essex
    i had this done and now i have nothing sounds brill
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Should not make any sound at all except maybe first thing in the morning when they clear any overnight rust. After that silence unless you have been racing or diving like an idiot and overheating them, then they would probably squeal like a stuck pig.
    3.2 v6 Signum and loving it
    Quote Originally Posted by marc vectra sri View Post
    Front or rear?
    The rears are known to suffer this when cold, as they are often chemically attached to the disc when the handbrake is applied
    The noise then disappears as the discs warm up
    Park the car in gear (as you should), don't apply the handbrake, and compare
    If you are getting a grinding noise with any brake application it is likely the pads are near the end of their life, typically the inside pads wear out first
  1. Replies: 14
    Last Post: 3rd September 2011, 20:23
  2. Brakes
    By Si-SRI in forum Suspension, Wheels & Brakes
    Last Post: 27th February 2011, 10:21
  3. my brakes
    By bigron1988 in forum Handling & Braking
    Last Post: 27th November 2008, 08:03
  4. Big brakes on my GSI?
    Last Post: 7th May 2007, 21:07
