Thread: iphone help
    Regular Member aerodynamic18's Avatar
    Aug 2007
    Lisburn, N.Ireland
    Default iphone help
    Guys i want to transfer the music from my iPhone back onto the computer which is running vista. Can this be done with out using software? i know this is a car forum but u guys know loads of things lol
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Need iTunes
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    you need to download and install itunes onto your vista computer, then use the usb cable to connect the iphone to the computer. there is no other way to do it.
    Regular Member Craig1985's Avatar
    harwich essex
    I don't believe this will move music onto your pc? Think this will also loose your iPhone music If the pc doesn't have the original music files ????
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    If it was purchased on the iPhone it will transfer them onto pc via iTunes
    If its from say phone and trying to add them to another pc and all music was purchased via iTunes it can also be done by contacting apple.
    Otherwise I think you'll need a 3rd party software
    Regular Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    I had to use a program called "Touchcopy" when my PC packed up last time. Worked a treat getting all the music and vids off the phone. Bad bit was having to reinstall all the Purchased apps again onto the new iTunes. But if it's just for music then Touchcopy should sort you out
    http://www.wideanglesoftware.com/touchcopy/index.php
    HIH
    Damo
    Regular Member bigdave1701's Avatar
    York
    If its music you've purchased through the iTunes store you can download iTunes onto your pc, log into your iTunes account and download again or plug your phone in and if will download from the phone to the pc. However, if it's music that's been put onto the phone from another source (eg; another pc) you cannot move the data from iPhone to pc. I'd also assume that if the music is from another pc, the iPhone will be synced to that pc, so connecting it to a new pc will lead to the handset being completely wiped.
    Regular Member DSmiddy's Avatar
    Jul 2011
    Bridgwater, Somerset
    Engine : 2.8 V6T
    Mileage : 50000
    As big Dave, just install iTunes, sign in and go to the iTunes Store, on the right you will see 'Purchased' from there you can download any purchased music again
  1. iPhone App
    By spennny in forum The 'Off Topic' room
    Last Post: 14th June 2011, 21:06
  2. Iphone
    By baz_cdti_sri_150 in forum General Chat
    Last Post: 26th April 2011, 20:39
  3. iphone
    By billyyoung in forum General items for sale
    Last Post: 8th April 2009, 22:35
