Results 1 to 10 of 11
Thread: Rear Knocking
    Apr 2011
    Darlo
    Default Rear Knocking
    Got a knocking from the rear, just going over bumps, had it on ramp, look at rear anti roll bar bushes, and they seem fine, the roll bar seems solid when having a tug in the middle but if i touch either end i get the knocking, is that still going to be the mounts? or is it possible drop links?
    its a 2005 vectra cdti 1.9
    and can anyone recommend me some new bushes if it is indeed that, or drop links if its that, ive looked at ebay at the bog standard ones, i know they are up to job but just wondering if anyone had links to others or anything like that
    cheers
    Ely, Cambridgeshire
    60 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Most likely suspects are the rear upper control arms, very common on all the Vecs and Signums. You'll see them referred to on here as "banana arms" sometimes too because of their shape.
    Regular Member skidmark1's Avatar
    Sep 2010
    cornwall
    Vehicle : 2.2 Direct
    Trim : SRI
    Engine : YH 2.2 petrol
    Mileage : 85000
    I had this and as my car was under warranty took it back to the steelers and they fitted a drivers side control arm, this did not cure the knocking so took it back again and they fitted new Bilstein gas rear shocks and all sorted
    Apr 2011
    Darlo
    are they easily changeable? are they connected to the rear arb?
    Apr 2011
    Darlo
    Quote Originally Posted by skidmark1 View Post
    its defiantly not the shocks, i had it up on the ramps at work and looked, and the noise from driving can tell its not. just googled the banana arms, are they attached to the drop links or rear arb at all? not many clear pics on google
    cheers for help btw
    Kingston Upon Hull
    http://www.vectra-c.com/forum/showthread.php?t=46991
    This will help
    I am having to do mine too
    leave the car on the floor then hold the top of the tyre and pull and push to check for movement
    Jacko
    Sep 2011
    leeds
    help just replaced rear left and right control arms and still a knocking noise on rear right cannot find any ideas
    Sep 2011
    leeds
    Default banana arms
    Quote Originally Posted by Ian-Highlander View Post
    changed both still got knocking what next
    London
    Hi all,
    I'm looking in to some rear knocking on my '53 Vectra. Assuming it is the banana arms, is there anything else that ought to be changed whilst the suspension is in bits? like anti roll bar bushes? i'm at about 70K miles
    Mevans
    birmingham
    change the bushes and it will b as quiet as a mouse, ive done mine today, 1 thing i found was if u havent got the wheels in just the right place the anti roll bar will feel thight on the bushes but jack up 1 wheel a little bit and there is so much play u will wonder why it hasnt dropped off
  1. rear knocking
    By tommy tess in forum Suspension, Wheels & Brakes
    Last Post: 22nd May 2015, 21:23
  2. Knocking from the rear?
    By Steven in forum Suspension, Wheels & Brakes
    Last Post: 8th November 2012, 22:49
  3. Knocking on rear
    By richy1974 in forum Suspension, Wheels & Brakes
    Last Post: 18th October 2012, 15:59
  4. rear end knocking
    By rob10 in forum Suspension, Wheels & Brakes
    Last Post: 30th June 2012, 11:32
  5. rear knocking
    By reeseandellie in forum Suspension, Wheels & Brakes
    Last Post: 7th October 2011, 17:28
vectra c banana arm done still knocking
vectra c 2008 rear end knocking
