Thread: vectra dti
    Jan 2010
    norfolk
    Default vectra dti
    hi just quick question do you need a puller to get injectors out of my 2.0 dti vectra on 53 plate thanks also is there any body can get glow plug out for me . i live in diss norfolk thanks
    exeter
    are you still having trouble with that . i thought you was going to drill it and use a extractor. i told you if it is snaped off then you got to take the head off and try from the inside or if it wont come out like that then you got to drill it out
    wirral
    56 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Injectors should come with but if wiggling. And tiny taps with soft hammer.
    As for glow plugs if it's snapped. It is a head off. Because drilling there's a chance swarve will fall into combustion chamber an course dramas.
    Has it snapped flush with head? It is possible you could maybe getting engine upto temp. Then get an easy out on it. But it's a slim possibilitie of it working
    Jan 2010
    norfolk
    Default vectra dti
    hi thanks for replies
    Jan 2010
    norfolk
    [QUOTE=octoman;1684276]hi thanks for replies so do not need puller but in haynes manual it says you do need special tool
    wirral
    56 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    They probably recommended a slide hammer.
    But they will come out with out a puller.
    Like a say bit of wiggling and gentle tapping
  1. mods could i do to my vectra 1.9cdti vectra suggestion of cheap vxr bumpers
    By lynchy-- in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2013, 00:17
  2. Vectra b rose bush for vectra c rear upper control arm
    By supernova_abh in forum Suspension, Wheels & Brakes
    Last Post: 14th September 2012, 19:26
  3. Silver Vectra (Vectra C Sticker) Southport Ocean Plaza DU56
    By mishima in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 29th September 2011, 23:25
  4. Replies: 9
    Last Post: 17th July 2009, 12:07
