Thread: eml light.... I need to help now?
    New Member Pablo1572's Avatar
    Jun 2009
    St.Austell, Cornwall
    Default eml light.... I need to help now?
    Can anyone help me?
    I have a Vectra 5 door hatch back 150 sri cdti 2007 with only 49K on the clock and driven miles with the engine management light on and done all I could to fix it with no luck.
    Over the Xmas break really got to work trying to sort it out. The new alternator before Xmas made me re-new my efforts to tidy the family car up. The third alternator which has amazed me to be honest on such a low mileage car. After the "stealers" fitted it I had a warning light reporting a fault with the power steering which I fixed myself as I thought they'd left the plug off the rack. After this the break lights acted oddly and again 4 bulbs rectified this.
    Today I cleaned EGR valve and boost sensor and emptied out fuel filter in case water had cause an engine management light fault.
    Any other thoughts on how I get the light off..... I've done the battery thing as well in my effort to sort out this car.
    Please help me there must be someone with the same problem..... last time the alternator was change it went out nearly straight away.
    Regular Member disco dan's Avatar
    Apr 2011
    Southport
    you got a fault code? done the pedal test?
    Regular Member PCMALT's Avatar
    Jun 2011
    Peterborough
    Vehicle : Signum V6 CDTI
    Trim : Custom lol
    Engine : Y30DT
    Mileage : 24000
    Have you had the codes Read to see what is causing the light to come on ?
    Jun 2009
    Default No Code?
    The peddle thing didn't work in my car and I'm not sure how to get the code. Thinking of buying a code reader now.
    All help is and will be appreciate - all comments welcome.
    Regards Paul
    Quote Originally Posted by disco dan View Post
    Pedal test doesn't work on most facelift models
    By Shadrack in forum Troubleshooting
  2. Replies: 4
    Last Post: 18th August 2012, 08:58
  3. Replies: 17
    Last Post: 16th August 2012, 10:07
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Fitted rear light,illuminated sunvisors and map reading light
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2008, 10:51
