Thread: what's this sign mean...
    Regular Member ShaunyB23's Avatar
    Dec 2011
    Birmingham
    Eek what's this sign mean...
    Hi what does this mean?
    Its ... ( ! ) With lines round it (like how you draw a sun lol)
    It come on under the rev counter where it tells a a doors open? Lol
    Also m mate got same car same year,model and engine etc..
    But when he reverses passenger mirror flips down to see the kerb. But mine don't ? Any ideas
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Bulb failure warning light?
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Think its your low brake pad warning light???
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Does it look like this? If so, it's the bulb failure warning light
    He has an option on the mirror that you don't. Ordered at the factory more than likely.
    Quote Originally Posted by ShaunyB23 View Post
    I don't have a name for this option, but only available on the Design and Elite trim
    Multi-contour driver’s seat with electrical reach, rake, height, tilt, lumbar
    support (including lumbar support height) and extendable thigh-support
    cushion adjustment, adjustable fan cooling and three-position memory
    (including door mirrors) and reverse-assist passenger’s side door mirror.
    Front passenger’s seat with electrical reach, rake, height and tilt adjustment
    Manual lumbar adjustment
    Electrically heated front seats
    I miss the extendable thigh support cushions, they were great on the Vectra B SRI
    Dec 2011
    Birmingham
    Thanks fr your replys and pics, does anbody know how to fix the bulb where this sign comes because u casnt see it only ver faint when the lighs are on at nite
    You need to work round the bulbs in sequential order
    Step 1
    Ask someone to apply the footbrake
    Check both rear upper lamps activate
    Step 2
    Turn the sidelights on
    Check both front sidelights, all four rear lamps, and numberplate
    Step 3
    Turn the headlamps, then full beam on
    Check both front headlamps and full beam
    Step 4
    Turn the foglamps on
    Check both front (if fitted) and rear (nearside only)
    Step 5
    Turn the engine off, return the key to the power position
    Switch the hazard warning lights on
    Inspect all six indicator bulbs
    Step 6
    Put the car into reverse
    Check both reverse bulbs
    If it is none of those, then replace all four rear lamps (as seen in Step 2)
    These are the ones that typically report as failed, but suggests one is near the end of its life
    Dec 2011
    Birmingham
    Lol thank you, but I should of been abit clear. But I ment the dash light that tells ou that your doors are open etc. Thank u for the above thi u do that later
    I don't think the Display in the tachometer can be dimmed / brightened from the variable lamp display, so it may be near the end of its life and/or faulty
    When mine comes on at night (as I drive with the interior lamps dimmed to their minimum) it is really bright I deal with the issue immediately to get rid of the warning
  1. Still no sign of my old GSi.
    By Hyperhart in forum Vectra C / Signum Car Chat
    Last Post: 20th June 2012, 19:41
  2. Please sign this...
    By spoons in forum General Chat
    Last Post: 1st February 2011, 13:39
  3. 888 sign Gio
    By dh.dti in forum Motorsport / Formula 1 etc. chat
    Last Post: 4th April 2010, 21:10
  4. I've Been Given A Sign
    By VauxVeteran in forum General Chat
    Last Post: 7th July 2008, 18:09
  5. sign
    By the-wizard in forum Comedy & Humour
    Last Post: 14th June 2008, 17:12
