Results 1 to 10 of 11
Thread: Rubbing noise nsr
    Regular Member pipamish's Avatar
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Default Rubbing noise nsr
    Now and again i hear a rubbing noise from the near side rear sounds like the pad is catching the disc as it rotates could this be my wheel bearing i notice it if my car has been parked up and its been wet or damp could it be handbrake im unsure
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    To add I only hear it when crawling and doing 10mph and less and I need to listen hard to hear it the way I would describe it is a metal on metal sound not squeaking more of a friction rough sound
    Engine : 1.9 CDTi
    Thats what mine sounded like.
    Turned out to be the inner pad on the rear worn right down.
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Update The noise is getting worse now I can hear it on the outside of the car if I put the window down and driving slow I can't hear it at normal speeds it sounds like a rubbing and a squeak now with every rotation of my rear wheel any ideas I'm going to jack car up today and have a look then I'm booking it into vauxhall
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    I would say it's pads mate
    As bearing would hear at all speeds
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    It must be I jacked the car up and rotated the wheel is it normal for the pad to rub the disc
    Quite common to have noisey rear brake pads when cold
    Complete a journey and compare
    Inspect the amount of brake pad material
    The outside pads are easy enough to inspect visually, but the inside pads are not so easy
    Equally, when releasing the handbrake there can often be a creak / bang noise as the inner rear pads release from the disc
    Finally, how many miles have the pads done?
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Oh I see I dont really drive the car that much even though I drive everyday I've only noticed this noise since it's been cold wet/damp and I only drive for like 10 mins every day
    I get this noise almost every time when setting off after a cold night
    I put this down to the brakes being hot when the handbrake is being applied and then curing to the disc overnight (chemical reaction)
    Equally, it is very noticeable where I leave the car for more than 24 hours
    This is a side effect of integrated rear pads and handbrakes
    The previous cars I had which had separate shoes and handbrake, within the disc (such as the Vectra B) never suffered the issue
    My previous Mondeo Mk3 was really bad for this
    As above, how many miles are on the rear pads and discs?
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    I couldn't answer that they are the original ones when I bought the car back in July I am going to change the rear discs and pads as I have only just had a full service and mot and had the front pads changed then. I have just took it on a drive and even going slow I can still hear it rubbing the disc it's really annoying
  1. grinding rubbing noise
    By coooky in forum Suspension, Wheels & Brakes
    Last Post: 28th November 2011, 09:49
  2. rubbing noise/droning ?
    By bigmac in forum Suspension, Wheels & Brakes
    Last Post: 30th January 2010, 10:54
  3. rubbing noise?
    By Messenger in forum Engine & Drivetrain
    Last Post: 24th February 2009, 21:21
  4. Rubbing noise
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 28th December 2007, 23:56
  5. rubbing noise from rear
    By robinhood66 in forum Vectra C / Signum Car Chat
    Last Post: 16th November 2007, 16:35
