Results 1 to 10 of 15
Thread: Aerial Base seal replacement
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Default Aerial Base seal replacement
    Hi Guys,
    Noticed that the aerial base seal on the roof has started to perish and split.
    Are thease an easy replacement or do you have to remove the aerial base itself?
    Its a DAB aerial from a 2005 Vec C
    Anthony
    Regular Member Keif's Avatar
    In the Garage
    You can get a replacement off eBay, but it's headlining down and aerial off to replace it.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    Didn't think you could buy the rubber seal separate ?
    In the Garage
    You can't from Vauxhall, but VW ones fit, and they're available via the bay for under £5.
    East Midlands
    Quote Originally Posted by Keif View Post
    Got a link mate i need one.
    Regular Member yorkshireborn's Avatar
    Apr 2006
    Rotherham SouthYorkshire
    Vehicle : saab 95
    Engine : 2.3t
    or use a black sealant from diy shop
    Regular Member farley2708's Avatar
    antrim n.ireland
    i replaced mine (had water in the boot wheel-well) 30mins tops
    put some black silicone under the base,tighten it down,then wipe off the access,might give it a better seal to the roof
    Are you VXR Enough
    13 Post(s)
    i cant find them on the bay fella??
    Regular Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    If I'm not mistaken, I think these are the ones that you are after
    http://www.ebay.co.uk/itm/4001341372...84.m1438.l2649
    Hope someone can confirm if the above is correct first though
    HIH
    Damo
    West Yorkshire
    Wrong shape for the dab aerial
  1. aerial rubber seal perished, where can i buy replacement?
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 3rd January 2013, 10:16
  2. DAB Aerial Rubber base rubber seal
    Last Post: 19th November 2012, 15:57
  3. Aerial base seal gone
    By paul wingnut in forum Electrical & ICE (including SatNav)
    Last Post: 10th December 2011, 18:06
  4. replacement aerial base/ info required
    By bobssignum in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2008, 18:07
https:www.vectra-c.comforumshowthread.php152613-Aerial-Base-seal-replacement
signum aerial base
vectra c change aerial seal
How to replace a seal on a vauxhall vector aerial
vauxhall vectra c sat nav roof arial
