Thread: Turbo Actuator valve - Squicking Noise - cdti 150
    Solihull
    Vehicle : safira
    Trim : Se
    Engine : 120
    Default Turbo Actuator valve - Squicking Noise - cdti 150
    I have a cdti 150 and the turbo actuator valve is squicking!!
    its driving me nuts because it sounds like the aux belt slipping.
    Is this a common issue??
    Do I need to replace it, or is there a quick fix????
    Remove the vacuum to it and its all quiet again!
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Could be the boost controller that's the problem possibly. It sits near at the slam panel above the boost hose and has the vacuum pipes connected to it.
    Solihull
    Vehicle : safira
    Trim : Se
    Engine : 120
    Nah its not the valve, definately not the pipes to it either.
    Its the actuator valve........
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    I presume you've removed the inter-cooler/manifold pipe to rule out the turbo ?, The pipe will have an oily residue but nothing else like a metallic residue or swarf.
    Dec 2011
    NEwcastle
    Is the boost controler the one near the egr or is it something different?
  1. Swirl valve actuator bar
    By Big Si in forum Engine & Drivetrain
    Last Post: 2nd February 2012, 08:34
  2. cdti turbo noise
    By coooky in forum Engine & Drivetrain
    Last Post: 1st July 2011, 12:51
  3. swirl valve actuator
    By wirrallad in forum Engine & Drivetrain
    Last Post: 4th August 2009, 19:54
  4. Swirl valve actuator
    By oxenburger in forum Engine & Drivetrain
    Last Post: 24th March 2009, 19:17
  5. 3.0 cdti turbo noise?
    By ziplex in forum Vectra C / Signum Car Chat
    Last Post: 30th July 2008, 22:39
