Results 1 to 3 of 3
Thread: Rear WiperProblem
    New Member Jonathan & Ali's Avatar
    Keith, Scotland
    Default Rear WiperProblem
    Help Required if possible,
    My rear wiper wont work when it turn it on with the stalk but the stalk clicks when i switch it off. No water coming out either. have checked fuse and seems ok. No broken wires either. Confussed.
    thanks
    Regular Member signumboy's Avatar
    Edinburgh/outskirts
    Engine : 2.0 Ltr Turbo
    Mileage : 38000
    not sure about the water part but the wiper tends to get seized up where is goes through the rear screen pull seal to one side and put some grease or WD40 on the actual shaft ....this fixed mine as mine was stopping in the middle of the screen
    Keith, Scotland
    ok will try that and let you know what happens.
  1. Condensation on Inside Rear Driver Side Rear Panel
    By akeem in forum Bodywork & Interior
    Last Post: 26th November 2012, 22:12
