Castrol GTX 10W-40 A3B4 - 4L
Castrol GTX 15W-40 A3B3 - 4L
http://direct.asda.com/on/demandware...Show?q=Castrol
Pity it's not the correct spec for Vec-C engines.
Vx recommend 5w/30 fully synth long life for all Vec-C engines.
I got 4L of Castrol magnatec the other month from Halfords for £17 !
It always pays to sign up for mailing lists
Not sure about the post facelifts, but from the 2004 pre-facelift manual (p253-256), for full oil changes (25,000 miles for petrol engines, 30,000 miles for diesel engines), you should use oil that conforms to GM long life specs (GM-LL-A-025 5W30 for petrol, GM-LL-B-025 5W40 for diesel).
However you can top up with up to a litre of oil that doesn't conform to those specs between changes. As long as it conforms to ACEA A3/B3 then 0W30, 0W40, 5W30, 5W40, 10W30 and 10W40 are all suitable for a top up. You shouldn't add more than one litre of oil that doesn't conform to the long life specs though.
For a full oil change though you should use the long life 5W30/5W40 stuff.
Or if you ignore the ecoflex service interim and revert to once yearly or 10,000m 10w40 can be used without problems ,use semi synth .
as above just change it at shorter intervals
