Thread: Swapping a turbo z20net big job?
    Worksop
    Default Swapping a turbo z20net big job?
    How big job is it taking the turbo off
    Jun 2009
    South Coast
    6 Post(s)
    Vehicle : Vectra, Signum & Insignia
    Engine : Z18XE,Z19DTH,Z20NET,
    Not a massive job tbh. You should read my turbo upgrade thread in the south central section.
    Its not as hard as it looks and feels more comfortable attempted wirh friends. I will be taking mine off next week and also taking it off again in feb when I replace it with something bigger. If you want to do it gather some member to help. Many will learn from such a day.
    Depending on where you are you may find a member who has already done this. I recommend this method because you will learn so much from it.
    We are always here to help, for a limited period. Protest time lol
    The wifes vec show car is currently being stripped for parts before i scrap it, keep an eye on the sales section.. https://www.vectra-c.com/forum/garage_vehicle.php?do=view_vehicle&id=709
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi tomo,it's a fair old job,remove engine top cover and V.belt cover,drain coolant,remove pollen filter housing,wiring harnesses,intake pipe and hose,wastegate hose,drain radiator,turbo heatshield,breather hose,turbo vacuum hose,cat temp sensor,turbo coolant and oil supply lines,release catalitic convertor(SUPPORT THE EXHAUST SYSTEM OR YOU WILL FRACTURE THE FLEXY COUPLING)exhaust pipe,turbo oil supply line banjo bolt,coolant return line banjo bolt,turbo support and heat shield holder,remove turbo.as i said tomo a bit of a job.when you fit new turbo prime turbine with clean engine oil before refiting oil supply line
    Jun 2009
    South Coast
    6 Post(s)
    What utter ********. I have done this on my drive with the help of a few members on here. A guide can be written but above is wrong.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    I agree with Nige I helped my mate with a turbo change on his z20net wasn't that bad at all mate as Nige says the above comment makes is sound very but it's not at all
    South east
    I think Jonny's got the wrong engine in his head, given that he's talking about a "v-belt cover" - no such belt or cover on the 2.0T
    May 2016
    UK
    Vehicle : Vextra
    Trim : SRI 2.0 TURBO
    Engine : 2.0 turbo
    Where abouts is tread. Need guide on how to remove turbo. Just incase I get stuck. Thanks
    Quote Originally Posted by Caveman_nige View Post
    Midlands - Head case Organiser Dog_Book's Avatar
    Oct 2013
    Derby
    182 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Just keep untightening things until it’s off in your hand
    Teapot Tuned 260/300
    https://www.vectra-c.com/forum/calendar.php
    May 2016
    UK
    Vehicle : Vextra
    Engine : 2.0 turbo
    Removed most of bolts and pipes, just struggling to get the bottom collar off the turbo, to separate from exhaust housing.
  1. Replies: 19
    Last Post: 6th September 2014, 13:54
  2. Z20NET Turbo
    By MattHD in forum Petrol Engine related
    Last Post: 4th April 2011, 10:48
  3. TD04L14T turbo for Z20NET (2.0 turbo)
    By Caveman_nige in forum Parts for sale
    Last Post: 10th October 2010, 13:23
z20net turbocharger removal
z20net turbo removal
z20net torbocharger removal
z20net forum site:www.vectra-c.com
how to change turbo on z20net
turbo removal z20net
