Thread: is this possible?
    Aug 2009
    on the hills
    Default is this possible?
    I know on the diesels you can blank off the egr valve however is it possible to blank off the 1.8 petrol engine? without any running issues. the reason is that i have replaced the egr and now there are small pieces of stuff getting into to the valve and it sticks open and runs like a pig until it is removed and the bits cleaned out, any helpers please.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Yep I thinks it's Easyer on the 1.8 and the 2.2s to actualy blank it
    Aug 2009
    on the hills
    any idea where i would get the blanking plate? is it a main agent part by any chance? cheers
    South east
    Use the metal from a soda can.
    Aug 2009
    on the hills
    so all it is, is a template cut from a coke can and that is it? does it affect the eml function or does it fool the eml to thinking that all is as it should be?
    north east
    have you looked on ebay ?
    Nov 2011
    Dewsbury
    blanked mine off (1.8) using a blanking plate I bought ages ago for an audi tdi egr. Just leave the EGR valve connected electrically and tie wrapped out the way allowing room the plunger to still move (unless its siezed like mine)
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Thought later 1.8's had them blanked off anyway?
    Nov 2011
    Dewsbury
    yeah they do, although I've not tried it I've heard if you unplug the EGR valve it'll throw the EML light up and run in 'open loop' mode. The ones with factory blanked valves probably have an ECU software update to run without them
    Nov 2011
    Dewsbury
    yeah they do, although I've not tried it I've heard if you unplug the EGR valve it'll throw the EML light up and run in 'open loop' mode. The ones with factory blanked valves probably have an ECU software update to run without them. I'll have to try it see what happens.
