Results 1 to 10 of 18
Thread: Judder at 50 to 60
    Dec 2011
    Lincoln
    Trim : elite
    Engine : 3.0d
    Year : 53
    Mileage : moon&back
    Default Judder at 50 to 60
    Just noticed that I seem to have a pretty big judder at 50 ish when under light acceleration . I don't think it's tracking as if I drop it into 4 th ( auto box) it doesn't do it . I'm hoping it's not the box but seems to look that way unless its engine mounts or something . Anyone shed some light or anything to look for ? Also sometimes when pulling up to a stop it's a bit juddery .
    Any help would be great
    Ben
    Almost certainly wheel balancing, that is the common speed range for front wheels out of balance
    Have the fronts rebalanced first
    Then take the car for a short run and compare
    If it is still present, then have the rears rebalanced
    Prior to that, you could check the tyres for uneven wear around the tread circumference (not the edges) and take tread depth readings at four points and compare
    Also look for unusual round or deep worn areas
    Finally, some general information about the tyres will help; age, mileage, and if they have been rotated during their life on the car
    Dec 2011
    Lincoln
    Trim : elite
    Engine : 3.0d
    Year : 53
    Mileage : moon&back
    I hope it's the Tyres but the judder is not coming through steering wheel and only under light acceleration . The Tyres are crap sunnys that were on it when I brought it . Oh plus only three are the same . My mate said the track rod end needs changing slight play in wheel , would this cause these symptoms ?
    Vehicle : .
    Trim : .
    Engine : .
    Year : .
    does it feel like someone big and heavy is in the back seat moving from left to right very quickly?
    Might be the drive shaft?
    East Ayrshire
    Trim : SRI XP1
    It's almost definitly not the tyres if it doesn't do it when you drop a gear. if it's only under light acceleration it would indicate maybe the transfer box or an engine component. If it's only doing it in certain gears then it is torque related not speed related hence why that would rule out the balancing
    Just seen the update re track rod ends. Yes because the wheel will flick slightly. Get them changed asap. its a cheap change, then start checking other things
    Dec 2011
    Lincoln
    Trim : elite
    Engine : 3.0d
    Year : 53
    Mileage : moon&back
    Yeah iv got a feeling it transfer/ engine . As iv selected neutral when it doing it and seems to stop . Only seems to be five gear at low revs
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Could be warped discs my transit van was doin it turned out very bad discs only did it in 5 th
    Dec 2011
    Lincoln
    Trim : elite
    Engine : 3.0d
    Year : 53
    Mileage : moon&back
    Discs ? Even with out braking ? just hope it's not the auto box
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Yep my transit did it mate what engine have u got
    Dec 2011
    Lincoln
    Trim : elite
    Engine : 3.0d
    Year : 53
    Mileage : moon&back
    3.0d v6 . Expensive? Or just live with it
  1. Judder and eml
    By Lordish in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2012, 07:41
  2. judder
    By marc vectra sri in forum Engine & Drivetrain
    Last Post: 28th December 2011, 14:41
  3. Judder in 1st
    By jongiddings in forum Engine & Drivetrain
    Last Post: 19th March 2011, 17:04
  4. judder
    By twaiter in forum Engine & Drivetrain
    Last Post: 14th July 2009, 21:26
  5. Judder at 2000rpm?
    By jamesr in forum Engine & Drivetrain
    Last Post: 28th January 2009, 13:49
