Results 1 to 10 of 17
Thread: Another leak any advice :*(
    Regular Member Shogun's Avatar
    Aug 2011
    Default Another leak any advice :*(
    literally my signum has caused me nothing but problems since buying it lol, this is the 2nd leak i now need to fix on top of the 650 bill i had last week
    talk me out of buying a mondeo ST someone!
    but as for now i need to fix it cos the condensation is so bad,
    basically i was messing about with the back passenger light and took it out of the roof lining and water started dripping, felt around up there a bit and its wet as hell,
    i have heard people on here complain about it being from the aerial base, but this is a signum not a vectra so just hoping its the same kind of fix, as to me the aerial base is a long way away from where the water is.
    rather than buying a used aerial base i was going to buy a dummy shark fit style one and go to town with clear silicon and hope for the best, so if anyone has any advice at all, literally anything it would be greatly appreciated, many thanks guys
    East Ayrshire
    Trim : SRI XP1
    I'll talk you out of buying a mondeo st but keep all sharp objects away from me. I owned one for nearly 2 years and hated every minute. It did have good gadgets, but rarely had a need to use them as it spent most of its life on a garage ramp
    Aug 2011
    really? i chose the signum over the st tdci due to mpg and it was a grand cheaper.. never heard a bad thing said about them.. till now
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Er Mondeo ha rubbish load of crap all i will say is DMf injectors big end bearing this list continues
    East Ayrshire
    Trim : SRI XP1
    Quote Originally Posted by paulvectrac View Post
    Sub frame slipping out of alignment, struts snapping (literally snapping in 2!) poor running, hesitation, cam shaft and crank shaft pulley/bearings cracking...Shall I continue! lol
    Aug 2011
    No mention of water tho!!
    Is it too much to ask of a car to keep you dry :'(
    Engine : 1.9 CDTi
    Sounds like the areal base is leaking the same as the Vectra can/does.
    As for a diesel Mondeo I will post up a picture tomorrow of one with the rocker cover removed due to the chain slipping and breaking the cam carrier and pulling the threads out of the head.
    Aug 2011
    Can you get a new aerial base from vauxhall guys?
    Don't see point in buying a used one and then having same problem 2 month later
    Or shud I take this opportunity to shark fin it
    East Ayrshire
    Trim : SRI XP1
    Quote Originally Posted by Shogun View Post
    A bit of silicone around where it goes through the roof might do the trick
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Quote Originally Posted by lee gsi View Post
    Any chance of that pic? I'm intrigued
  1. Oil leak - need some advice
    By Chip in forum Engine & Drivetrain
    Last Post: 5th January 2013, 19:54
  2. diesel leak - any advice
    By mooney in forum Engine & Drivetrain
    Last Post: 13th February 2011, 20:16
  3. diesel leak - any advice
    By mooney in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2011, 02:29
  4. Water leak - Advice please!
    By Ricksh in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2010, 10:08
  5. Sprung a leak, advice please
    By Gonch in forum Bodywork & Interior
    Last Post: 31st March 2010, 09:25
