Results 1 to 10 of 13
Thread: Steering play/clunk
    Glasgow
    Default Steering play/clunk
    Hey guys,
    The cars been niggling over the past week. Noticed a clunk through the steering wheel when taking up the slack whenever turning the wheel its been getting worse gradually over the past week so phoned the local dealer (still under warranty) and they could'nt get it in today. Took it to a local independant garage to see if it was something simple and the guy came out for a drive and then got it on the ramp.
    The bad news is there is playing in the steering rack or column somewhere and he reckons requires them to strip it down to diagnose where the problem lies. Just aswell its under warranty i imagine this would be expensive.
    On a side note my dust guard on the back of the O/S/F disk had to get levered back for the second time in a year as it starting rubbing the disk again when turning left but at least thats sorted.
    Anyone else has similar problems with the steering rack/column???
    East Ayrshire
    Trim : SRI XP1
    It may be what alot of people have experienced. The intermediate shaft (steering knuckle) develops a little bit of play. It's in at the engine bay side where the pinion hoes into the rack, Theres a bolt (10mm possibly) on a universal joint. I nipped mine about about 1/4-1/2 turn and it's been fine since. That was back in march. Mine is a cdti so don't know how much access you have in the engine bay
    Glasgow
    Thanks for that ill see what they say when it goes in. Mine may be different as you have electro hydraulic steering the Z28's have normal power steering. The mechanic who looked at it said there was nothing he could nip up with out a strip down so ill see what vauxhall say after new year.
    East Ayrshire
    Trim : SRI XP1
    Although the 2 different types of power assistance it's still the same basic set-up. rack and pinion or steering box (only usually in 4x4's and trucks) So it will have an intermediate shaft. It may be that you'rs isn't accessible given the amount going on under the bonnet. Hope you get it sorted soon tho
    Glasgow
    Thanks, will update this when its sorted.
    Regular Member simonwrx's Avatar
    Oct 2011
    Oxon
    Have the same fault currently
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Sounds like play in the inner tie rods
    Glasgow
    Nope mine is definetly the rack/column, when it was on the ramp its pretty clearly heard.
    Jul 2012
    telford
    i have the same problem when the wheels are straight ahead possiton and rocking the stearing wheel from side to side it clunks like mad ive had the front end up in the air and no noise it wouldnt bother me normaly but it realy sounds like somthing is wrong
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Try pinch bolt on steering rack
  1. vectra steering clunk
    By stooby in forum Suspension, Wheels & Brakes
    Last Post: 10th August 2011, 12:01
  2. Replies: 6
    Last Post: 13th March 2011, 10:47
  3. clunk from steering
    By idobigmls in forum Suspension, Wheels & Brakes
    Last Post: 1st August 2009, 07:13
  4. Play in steering
    By SJG in forum Vectra C / Signum Car Chat
    Last Post: 13th April 2008, 10:26
  5. steering play
    By chinky in forum Vectra C / Signum Car Chat
    Last Post: 3rd September 2007, 21:39
