Results 1 to 10 of 21
Thread: Is everything here for Park Pilot?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Default Is everything here for Park Pilot?
    Will I have to make looms for it or is everything there?
    http://www.ebay.co.uk/itm/VECTRA-C-F...item1c21f8fabd
    Wirral / ellesmere port
    12 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    hi m8
    yeah it all seems there,you may have to get the body loom making
    to run from the front bumper to the rear rec if its not already present
    in the body loom which most of the time its not.
    you can also have the rear speaker wired in through the rec as long as
    youve got the ribbon cable tucked up in the roof lining for the rear pp
    speaker.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    If the ribbon cable for the speaker isn't there is it just a case of getting one and plugging it into the REC?
    12 Post(s)
    Trim : elite
    Year : 2011
    no m8 you wud have to use run the 2 wires up to the roof to use the
    oe speaker,its pretty easy to do thou but im sure you will find the ribbon
    cable with the little plug on it.
    the ribbon is normally taped up onto the roof lining and runs up alongside
    the grab handles on the passenger side lining
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Cheers for that Andy much appreciated
    12 Post(s)
    Trim : elite
    Year : 2011
    no probs m8
    if you need any assistance on the wiring etc then i be happy to help
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Quote Originally Posted by andy.l View Post
    no probs m8
    Yeah keep your inbox clear
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    ARGH! ****** typical. The kit arrived and the rear boot loom has connections for 2 boot lights and the rear bumper loom has no plugs for the number plate lights.....it's a siggy or vec estate loom
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Not from estate.. then it must be from siggy.... or could it be from a saloon.. (dont know witch one that have the plate in on the boot)
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Saloon rear bumper is the same as the hatch so it must be a signum setup. If I find out for definate i'll contact the seller as it's clearly marked in the listing that it's for a vec
  1. Park Pilot
    By Simon_Fuller in forum Electrical & ICE (including SatNav)
    Last Post: 27th September 2012, 11:17
  2. Park pilot alert but I don't have Park Pilot
    By krisby in forum Vectra C / Signum Troubleshooting
    Last Post: 21st November 2011, 10:58
  3. park pilot
    By andy bo in forum Electrical & ICE (including SatNav)
    Last Post: 9th March 2011, 23:20
  4. Park pilot
    By hairy31 in forum Electrical & ICE (including SatNav)
    Last Post: 25th April 2010, 16:58
  5. park pilot
    By tditony in forum Electrical & ICE (including SatNav)
    Last Post: 12th August 2009, 11:02
