Results 1 to 10 of 13
Thread: Trailer tell tail light?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Default Trailer tell tail light?
    Is the tell tail warning light omitted from the Vec C and Signum facelift?
    Do they get round that by having bulb failure warning instead?
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Bump
    There should be one additional trailer lamp only in the display cluster
    See handbook
    The Driver Info Display only covers the bulbs within the car
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Bulb failure warning covers trailer bulbs too, this is the second vec i've fitted the genuine electrics to and the previous one had bulb failure and the tell tail light. This one doesn't have the tell tail light though
    Never installed or used on Vectra, so refer to handbook
    From memory the latest one is car only
    Jun 2006
    St. Helens,Merseyside
    ive fitted a PCT towbar but used OE loom and trailer module,when i activated it i got a few options inc reverse light check and brake light "bulb or led" check
    ive not removed an indicator bulb to see if they are in the check system
    iirc there is a light on the dash to say trailer socket in use
    Quote Originally Posted by Mike1.9CDTI View Post
    That is also what the handbook on mine states
    Nothing about a failed bulb in the trailer being reported in the Driver Info Centre (however, as above, I've never installed so not able to confirm)
    Oct 2010
    Lincoln
    My Vectra C 56 plate is fitted with Vx electrics but no indication on the dash at all just the audible warning from the REC. Not sure about bulb failure, never tried it
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    You either make half of your posts up or take a bit of the truth and twist it IMHO.
    Full Member Big Sig's Avatar
    If it helps I remember reading that when installed and set up the car will check the lamps on the trailer. That would have been pre facelift though.
  1. trailer indicator tell tale light. yes or no?
    By brotherkennyh in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2011, 21:11
  2. Tail light/number plate light wiring...
    By kyuudousha in forum Electrical & ICE (including SatNav)
    Last Post: 26th December 2010, 12:34
  3. Trailer Tell Tail
    By Cam in forum Vectra C / Signum Car Chat
    Last Post: 23rd July 2010, 13:35
  4. Should I have a trailer light....
    By lds1973 in forum Electrical & ICE (including SatNav)
    Last Post: 28th March 2010, 20:29
