Thread: Stripped thread(EGR Valve)
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    Default Stripped thread(EGR Valve)
    I managed to strip the thread wheil replacing my EGR valve.Its the thread inside the head not on the actual bolt.Its the small 10mm bolt thats infront of the coolant bottle and not the stud bolt that holds the engine over rubber thiny.
    Going by the head thread that was on the bolt,its stripped from about 3mm from the end of the bolt.I really need to get something sorted as i want to get a new EGR valve a.s.a.p but dont want to have it fitted with 1 bolt not tight and the risk of the gasket leaking.
    How deep does the thread go inside the head as im really hoping i can just get hold of a longer bolt?
    Regular Member david-bell's Avatar
    eastlothian scotland
    Vehicle : vectra vxr
    Trim : vxr
    Engine : 2.8 v6 turbo
    Mileage : 31000
    drill it out bigger and helicoil it
    http://www.emhart.com/brands/heli-coil
    Rochford
    I did this on mine so I brought some slightly longer bolts and some thread and separate nuts. There is a small amount of thread left not used inside.
    This fixed it no problem. Got the bolts off ebay. I think they were 5mm longer than the standard ones. But cannot remember the diameter.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Helicoil is your best bet.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Quote Originally Posted by Critch View Post
    This.
    I stripped mine, and helicoiled all 4, much better that standard.
    Aug 2011
    Basingstoke
    Trim : SRI
    cheers guys.
    i will have a look on ebay for a longer bolt but if nothign comes up ill get them helicoiled
    stockport
    Thumbs up
    Quote Originally Posted by stupot555 View Post
    You can get a longer 10mm bolt with 2 nuts from any local engineering factors shop/store.Save's helicoiling which can turn out to be expensive if your not careful,as they usually want to do all four bolts to make it cost effective.FELIXX.
  1. Egr bolt thread stripped?
    By felixx in forum Engine & Drivetrain
    Last Post: 28th July 2015, 20:39
  2. Another EGR valve thread but please Help ME
    By spikeyboi33 in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2013, 04:04
  3. 1.8VVT stripped spark plug thread
    By Cleared To Land in forum Engine & Drivetrain
    Last Post: 14th December 2012, 15:15
  4. Another egr valve thread ;)
    By durham4416 in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2011, 15:53
