Results 1 to 10 of 14
Thread: Retrofit TPMS on Vectra C 2.8 V6 GTS
    Nov 2011
    Valkenswaard
    Default Retrofit TPMS on Vectra C 2.8 V6 GTS
    Hi,
    I'm want to retrofit some functions on my Vectra.
    One of them is TPMS.
    I bought these wheelsensors and main unit http://www.verklein.nl/0nD8p.
    Can someone please help me.
    Which parts (GM partno's) do I need more.
    Do I need the two receivers in the wheelcap also?
    Which parts do work with the set I already have?
    THNX in advance
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Look In the forsale sexfilm Think the rest is there
    Regular Member BYGino's Avatar
    Jun 2011
    Lanarkshire, Scotland
    Quote Originally Posted by kenp View Post
    Sexfilm? Is that one of those auto-correct moments?
    There's a how to for TPMS on here somewhere I'm sure but can't seem to find it at the minute, just try searching the forum, you should be able to find it.
    Wirral / ellesmere port
    12 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    Quote Originally Posted by Jerom747 View Post
    Hi,
    THNX in advance
    hi m8
    firstly that module youve bought with the wheel sensors is the wrong
    module,thats only for the corsa d,astra h,zafira b,theres a different module
    for the vectra and signum and also you cant really fit a 4 reciever tpms
    system to a facelift as its a totally different setup as the facelift
    only needs 2 recievers and getting the wrong sensors and module will cause
    mal function.
    the wheel sensors are the right ones so your ok there,you will also need to
    add wiring onto ya car on the rear to were the rear reciever wud be located
    you shud already have the bodyside wiring already present going to the
    front reciever location.
    apart from this then once all parts fitted then its a tech2 session to
    activate everything.
    Engine : 2.2 Direct
    Quote Originally Posted by BYGino View Post
    yes... that was a auto-correct on my iphone..
    Engine : 2.2 Direct
    it was this forsale add i was thinking about:
    http://vectra-c.com/forum/showthread.php?t=152138
    12 Post(s)
    Trim : elite
    Year : 2011
    the parts you need is as follows and are for pre facelift 2005 my and
    for all facelifts
    13172984 module
    13172977 reciever
    13172992 reciever
    wheel sensors (ident AC)
    Nov 2011
    Valkenswaard
    THNX very much
    I'll try to find some on ebay
    Nov 2011
    Valkenswaard
    Okay, but according to the listpart above these won't fit either
    but thanks for helping me
    12 Post(s)
    Trim : elite
    Year : 2011
    THNX very much
    you just wont find any on ebay as there as rare as hens teeth,your better
    buying from dealer as there pretty cheap enough
    the module is about £75 plus vat
    the recievers are about £16 each plus vat
    and youve already got the wheel sensors so thats really you need apart for
    any wiring you may need retro fitting which aint much tbh
  1. For Sale: Vectra/Signum TPMS module+ front rear recievers
    By Sebastian in forum Parts for sale
    Last Post: 7th October 2012, 22:31
  2. Retrofit ESP ? what do i need....
    By kenp in forum Handling & Braking
    Last Post: 4th June 2012, 17:27
  3. Retrofit
    By Jabbekot in forum Styling
    Last Post: 1st April 2010, 22:22
vectra c tpms retrofit
vectra tpms
vectra c tpms breakdowwn
