Thread: A noise on the left
    Dec 2011
    NEwcastle
    Default A noise on the left
    1.9CDTi
    There is a strange noise from the left side of the car. It starts at about 25mph and does increase with speed.
    With the car in and out of gear it is there, but the pitch changes slightly.
    It doesn't get much louder at any time.
    Describing the sound it sounds like a whir or maybe whine, but it doesn't sound like a typical gearbox whine and it doesn't appear t come from the turbo.
    Initial thoughts was a wheel bearing, but it's not that characteristic hum.
    Stationary in neutral the sound can't be recreated.
    We have decided it's the left side due to it being loudest from there, can be heard slightly with straining with the window cracked, but not on the right.
    Anybody able to suggest any likely culprits?
    Known faults at this moment in time - swirl bar is off.
    Tyre noise ? Does it change with different road surfaces ?
    Sent from my iPhone using My thumb
    morecambe
    28 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Yep my bet on cheap ditch finders
    Dec 2011
    NEwcastle
    Changed tyres from my 17 to 16s noise is present with both.
    That was my initial thought as well.
    Sometimes it sounds as if it is waterlike - drives me mad, because I know it's there, if I listen to music, i have to turn it down every so often to see if it has got any worse, which it hasn't.
    Vectra-sport Admin Dre's Avatar
    Vectra-sport Admin
    Vehicle : VXD
    have you checked your pads and discs ?
    Dec 2011
    NEwcastle
    Both just done yesterday.
    Pads worn, discs fine.
    CV boots fine, drop links fine, drive-shaft seals just replaced.
    Pads and discs rear completely changed.
  1. Noise from F/O/S wheel when turning left
    By hothatch in forum Suspension, Wheels & Brakes
    Last Post: 9th January 2013, 23:24
  2. Noise from left front wheel :-(
    By rollercoaster63 in forum Suspension, Wheels & Brakes
    Last Post: 23rd May 2012, 10:31
  3. noise front left
    By msqualo in forum Vectra C / Signum Car Chat
    Last Post: 11th November 2011, 01:05
  4. Chirping noise when turning left
    By MrLOL in forum Vectra C / Signum Car Chat
    Last Post: 12th August 2009, 23:50
  5. Squeaking noise from back left of car?
    By RSV_Ecosse in forum Vectra C / Signum Car Chat
    Last Post: 22nd April 2007, 09:39
