Thread: Air/fuel leak
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 172000
    Default Air/fuel leak
    Hi guys I've got a problem with my cdti 150. When the car is idling there is a noise coming from top right side of engine. It's like a fast paced on off blowing noise, and you can also feel something blowing that's in sync with the noise. I'm not sure if it's coming from the furthest right injector or the furthest right swirl valve, but it would appear to be in that area. Thanks for any advice
    wirral
    33 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Check egr is tight.
    But it's probably injector seal gone.
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 172000
    Dam injector seal as gone, has anybody got a clue on the cost f the seals?
    wirral
    33 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Their not much. Less than a couple quid each
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 172000
    Guys I've replaced all the injector seals but now injector 1 & 2 are leaking. I've checked all the clamps are tight, so not sure what is going on
    Any ideas guys?
    wirral
    33 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Did you give the area in the head a scrape with small flat blade screwdriver or similar before refitting?
    Could be a bit of carbon build up is not allowing them to sit properly
    Mar 2007
    Gloucestershire
    Quote Originally Posted by neill View Post
    Any ideas guys?
    without hijacking thread - I am about to replace my injectors and wondered if the copper crush washers have to be fitted a certain way around. To me they look like they have 'flat' side and a slightly rounded side. Should the flat side be against the injector and the rounded side sits in the seat?
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 172000
    all sorted now guys, it was the washers on top of the injector clamps that were fooked.
    As for the injector seals, the ones from vx dont have a different side, there just an even washer so doesnt matter what way they go round.
  1. fuel leak?
    By johp778 in forum Engine & Drivetrain
    Last Post: 26th May 2012, 18:56
  2. I need help ... Ive got a fuel leak ???
    By renton608 in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2011, 06:51
  3. fuel leak
    By mani2002uk in forum Engine & Drivetrain
    Last Post: 5th October 2010, 16:19
  4. Fuel Leak
    By silver-tongue in forum Engine & Drivetrain
    Last Post: 24th September 2010, 12:42
  5. ****** Fuel leak AGAIN!!
    By bill1250 in forum Vectra C / Signum Car Chat
    Last Post: 9th May 2008, 17:13
