Results 1 to 10 of 15
Thread: Problem in stack
    Dec 2011
    Portugal
    Default Problem in stack
    Hi People..
    I´m a portuguese and i have one Opel Vectra GTS 1.9 CDTi 16 V
    I have one problem im my gts. When activate the position on my stack "wash front window" dont happen nothing. the others funtions on the stack function 100% .
    This problem happen someone in forum ?
    Somebody can help me ?
    Mário
    VIP-Member puppet's Avatar
    East Ayrshire
    8 Post(s)
    Vehicle : Insignia 1.8 SRi
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    Can you hear the washer motor running/whirring when you operate the stalk?
    If you can't, then my guess would be that the motor/pump may well be broken. Easy enough to replace, they are in the passenger side (L/H) front wheel arch, just under the headlamp. Need to loosen the plastic liner in the wheel-arch to get to it. Might also be worth taking the electrical connector off of the pump and trying a voltmeter across it when you are operating the stalk, that would confirm it as faulty if you get zero reading.
    Or, if you can hear the motor running when you operate the stalk, there is a small black filter on the screenwash bottle which often blocks. A quick clean would perhaps get it going again.
    Have a looky here for how to remove and clean it:
    http://www.vectra-c.com/forum/showthread.php?t=107593
    Hope that helps!
    Regular Member smiler1982's Avatar
    Nov 2011
    Northampton
    I did this and it works wondered however now the back washer works but the front does not. I think maybe there is a blockage in the pipe near the pump. What is the best way to clear this pipe out?
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Have you checked the fuse/relay for the pump?
    morecambe
    37 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Think u mean stalk also u have posted the same thread 3 times
    East Ayrshire
    8 Post(s)
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    I think I'd take the pipe off in the scuttle panel, near the washer jet, and also down at the pump, and then just give it a good blow through.
    Engine : 2.2 Direct
    Now merged to 1 thread.
    Nov 2011
    Northampton
    Thanks puppet, much appreciated
    Dec 2011
    Portugal
    Thanks for your comments...
    The water pump is not, because when i activate wash rear window is work... Just the position "wash front window". Exist any relay in a front to comand this operation ?
    Engine : 2.2 Direct
    yes there is.. but not just for the front..
    But it still can be the pump.. as it rotates the other way when going to the back window rather than the front.. but try to see if any blokage to the pipes.
  1. Rear Signum Light problem problem - help
  3. How does a remaped 2.0T stack up against 9-3 AERO
    By accveccysriturbo in forum Petrol Engine related
    Last Post: 9th September 2010, 14:05
  4. Tyre Stack
    By Tadpole in forum The 'Off Topic' room
    Last Post: 18th July 2009, 01:09
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
