Thread: Can If fit wheels with an offset of 45 to my Signum
    Nov 2011
    Osnabruck
    Default Can If fit wheels with an offset of 45 to my Signum
    I have a set of aftermarket alloys that have an offset of 45 and were fitted to a Vectra 3.2. They dont seem to fit the Signum too well and i havent fitted them as the bolts dont want to go in easily. I wondered if the offset is wrong to fit to a Signum. Any ideas ?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    The Offset range for the Vectra and Signum is 35 to 43. 45 means they are sitting right in the wheel arch so possibly that's the problem. Also you will have the added trouble when turning the steering wheel - the front wheels will rub on the wheel arch.
    May 2011
    bispham, blackpool
    did you see them on the 3.2 or is it just what the seller said they were on
    as it sounds like you mean the pcd if the bolts wont go in the last owner might of used i think their called wobbly bolts
    my last set of alloys had a offset of 45 and they fit the vectra but were catching on brakes spent around £200 buying different sizes of spacers in the end just sold the alloys and kept my orginals and put 20mm spacers on
    Nov 2011
    Osnabruck
    The chap I got them off said that they were off his Vectra 3.2 although I didnt see them on there! I just assumed that they would also fit a Signum. I also had the bolts of him so dont think he used wobbly bolts.
    Im guessing that I do mean the PCD ? The wheels do fit on (with 5mm spacers) but just seems that the bolts dont sit in 100% snugly. Kind of feels that you have to put a little bit of force (which is when i thought I wouldnt bother)
    May 2011
    bispham, blackpool
    Quote Originally Posted by Herman Villa View Post
    do the bolt look the same as the orginals just a little longer if 5mm spacer are being used the bolts you will need will have to be 5mm longer than your standard vx wheel bolts to be safe
    as a signum is a vectra its the arse thats different so vectra wheels will fit signum
    the only difference i found was a 3.2 has bigger brakes on the front than other vectras
  1. What ET offset?
    By SpiD in forum Vectra C / Signum Car Chat
    Last Post: 19th November 2012, 18:20
  2. 19inch Wheels.. What Offset???
    By Brian150 in forum Suspension, Wheels & Brakes
    Last Post: 11th April 2012, 19:36
  3. NEw wheels what offset do I need
    By toast in forum Suspension, Wheels & Brakes
    Last Post: 29th March 2011, 21:37
  4. SIGNUM ELITE WHEELS TO VECTRA SRi WHEELS
    By MRLUBBERLUBBER in forum Vectra C / Signum Car Chat
    Last Post: 4th November 2008, 12:09
  5. Wheels/offset ?
    By craigmerry in forum Styling
    Last Post: 29th January 2008, 23:14
vectra 3.2 wheel offset
would a 45 offset fit a vectra c
