Thread: anyone got a wiggly/slack gearstick?
    Dec 2011
    SCOTLAND
    confused anyone got a wiggly/slack gearstick?
    When driving home from work i noticed thet my gearstick seems very slack?? Goes into gear fine but even in gear it still wiggles from side to side. Maybe about 1centimetre play each side. Doesnt do it in reverse. Can it be tightened somehow or is this normal? How is your gearstick on vec c? 06 1.9 cdti sri 150
    That is usually a symptom of resting left hand, wrist, or arm on the gearstick during normal driving, so none of that issue here; both hands on steering wheel
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    There is a plastic joint that that brakes up causing this problem
    Jul 2011
    UK
    Year : 06
    Mine is the same moves side to side when in gear
    Dec 2011
    SCOTLAND
    Is it normal or does it need fixed?
    Full Member
    South West
    As long as it does not jump out of gear, and you can live with the movement then its fine. Its more of a personal preference if you want to get it sorted out.
    Quote Originally Posted by b1lly View Post
    My car has 135K miles and there is virtually no movement, but I have been in some cars where there is a lot of movement
    I am of the opinion that all parts should be in good working condition
    I would therefore have this repaired, but it depends on the cost
    Equally, you could leave it to next service and have the garage that you use prepare a quote or authorise them to automatically repair it for a set amount limit (which is the process I use)
    Equally, you could replace the worn components yourself, if this is your thing
    Sadly it's not mine, the days of me picking up tools are long over
    Regular Member scarydeath's Avatar
    Sep 2009
    County Durham
    Mine wobbles a bit too :-( Expensive fix?
    Dec 2011
    SCOTLAND
    Cheers guys think i'll get it checked out......... Eventually! Lol
    Regular Member insignia28's Avatar
    Mar 2011
    Warrenpoint, NI
    It wont wobble in reverse as when you lift the collar it slides onto a runner that holds it in place.
  1. slack bonnet release handle, is it adjustable?
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2013, 11:20
  2. Shunt on clutch biting and generally feeling slack
    By Damwee in forum Engine & Drivetrain
    Last Post: 28th August 2011, 11:02
  3. I've got a slack box.........
    By rushy in forum Engine & Drivetrain
    Last Post: 15th June 2011, 20:34
  4. slack handbrake!
    By signum03 in forum Vectra C / Signum Car Chat
    Last Post: 20th August 2009, 19:21
  5. Automatic Gearbox Slack
    By Russell in forum Engine & Drivetrain
    Last Post: 4th July 2008, 13:56
why does my gear stick wiggle from side to side
