Results 1 to 10 of 11
Thread: Replacing Wing Mirror Unit
    May 2007
    Question Replacing Wing Mirror Unit
    I'm about to replace my O/S Wing Mirror. The Haynes manual says the door card has to be removed before the tweeter unit. The How2 photos seem to suggest that the door card doesn't have to come off.
    Does the door card need to come off ?
    If it doesn't, is it easier to take it off ? Is it easy to take the door card off ?
    Aug 2009
    Wakefield
    I found that you had to take the door card off as one of the mounting bolts for the mirror is just below the top edge of the card and no matter how i tried i couldnt get in to it with the door card still on..... I found the door cards on the vectra one of the easiest to get off though!
    Full Member andy.l's Avatar
    Wirral / ellesmere port
    8 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    no door card doesnt have to be removed,ive done a fair few of these
    just remove the tweeter trim and then you can access the screws,it will be
    tight and be carefull that you dont lose the screws down the door skin,
    ya best using a magnetic bit so it doesnt fall down.
    2011 insignia elite tourer 2.0 cdti 160 manual,silver
    May 2007
    Quote Originally Posted by MattDC View Post
    In terms of getting the door card off, I've seen the How2 on this site which looks pretty informative, but has anyone come across any other 'guides' which might help ?
    May 2007
    Quote Originally Posted by andy.l View Post
    just remove the tweeter trim and then you can access the screws,it will be tight and be carefull that you dont lose the screws down the door skin, ya best using a magnetic bit so it doesnt fall down.
    In terms of actually removing the tweeter trim and mirror and replacing, are there any good "guides" around ? Also, any "guides" to removing and replacing the covers especially the small cover ?
    Aug 2009
    Wakefield
    The tweeter trim comes off very easily, simply pull away it away from the door starting at the top.... nothing more to it......
    May 2007
    Any further ideas, guidance or likns to guidance elsewhere ?
    Aug 2009
    Wakefield
    It really isn't that hard mate..... just get on and do it! Lol.... even if you need to move the door card as I had to it should only take you 15 mins!
    May 2007
    Question Swapping Mirror Base Cover
    I also need to swap the painted covers from the damaged mirror onto the new mirror. The main cover seems relatively straightforward to swap, but the small, base cover seems to be difficult to remove according to the few bits of info I can find. Anyone got any guidance/links for this ?
    Last edited by Englishman; 27th December 2011 at 04:00. Reason: correcting minor typo
    May 2007
    Default Swapping Mirror Base Cover
    Quote Originally Posted by Englishman View Post
    I'm not sure if this is following accepted protocol, but I think I'll start a new thread with this question.
  1. Replacing o/s wing mirror glass
    By ROY GBIV in forum Vectra C / Signum Car Chat
    Last Post: 21st March 2011, 13:49
  2. Replacing CIM unit
    By r.bailey63 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd May 2010, 21:18
  3. Replacing head unit
    By fattony in forum Electrical & ICE (including SatNav)
    Last Post: 30th December 2008, 14:20
  4. Replacing Head Unit
    By Adamant in forum Vectra C / Signum Car Chat
    Last Post: 24th May 2006, 13:25
