Thread: Boot Lock
    May 2006
    Bedford
    Default Boot Lock
    Hi, can anybody help?
    2004 Signum, when I press the boot release button on the driver's inside door handle or the key i get the usual beep or flash from the indicators and the number plate light comes on, but the squeeze pad on the outside of the tailgate won't work.
    If i unlock all the doors (ie press the unlock button on the remote key twice) the boot semi-unlocks - I hear the latch release, the boot light comes on but again I can't use the squeeze pad on the tailgate to fully release the lock. This means folding down the back seats, hauling the golf clubs out into the passenger compartment then climbing into the boot from inside to use the key in the emergency release on the inside of the tailgate to get the damn thing to open.
    It was all working fine when I left home yesterday, but half an hour later when I got to my destination it was displaying the above behaviour!
    Covered under warranty, or is this one like the non-washing screen washers where I need to have a furkle around to sort out?
    Many thanks
    Pete
    Regular Member vectravirg's Avatar
    Bolton
    Covered under warranty, got main dealer to replace the mechanism on mine a couple of weeks ago for similar problem. On a vec, not a Signum though.
    May 2006
    Bedford
    Thanks vectravirg, i'll phone main stealers tomorrow, should get an appointment for about 2 weeks time which kinda suits when i'm back from the business trip!
    Regular Member Geoshaw's Avatar
    Armadale (West Lothian)
    The pad will be stuck in, it is just a hinged metal flap which corrodes and jams behind the rubber. This pushes against a little microswitch. If it is already pressing the switch it won't release the lock. If you remove the inside panel and loosen the 2 bolts holding the handle you should be able to pull back the rubber cover on the outside and spray a little wd40 or similar on the flap to work it free.
    I had to do this on a vec estate at work last week, it now works fine.
    i'll remember that one G.. nice tip...
    May 2006
    Bedford
    Well it had to wait a week as I'd been away with the car parked up at Heathrow ....
    Followed the above instructions and found that the inside of the release mechanism (where the hinged flap is located) was full of muck and gunk , quick clean out and application of WD40 sorted that out.
    One quick tip if doing this yourself: once you've wrestled with the tailgate inside trim to get that off (including the T25 screw inside the inner handle), undo all the 6mm nuts which hold the long plastic bit that holds the tailgate release and the number plate lights. Then you can access the nuts which hold the tailgate release in place which makes the job of putting the rubber cover back on soooooo much easier!
    And watch out for the clips which hold the inside trim in place .... the ******s fly everywhere!
    The golf clubs are once again accessible ...
    Peter
    Glad you got it sorted mate.
    May 2006
    Bedford
    Oh, sorry, thanks to Geoshaw for the solution!
    Regular Member pogo's Avatar
    Feb 2006
    Vehicle : Insignia
    Trim : Sri
    Engine : 2.0 turbo petrol
    Year : 2010
    well done george mate some good advice there
  1. Boot Lock no whirring noise and wont lock or open
    By meridianghost in forum Troubleshooting
    Last Post: 17th December 2012, 14:16
  2. Boot Lock
    By alancallaway in forum Electrical & ICE (including SatNav)
    Last Post: 23rd June 2012, 18:35
  3. boot lock
    By alden11 in forum Vectra C / Signum Car Chat
    Last Post: 3rd March 2011, 17:04
  4. Boot lock
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2008, 21:08
  5. boot key lock
    By selv1980 in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2007, 07:31
2004 vectra c estate boot lid wont open www.vectra-c.com
