Results 1 to 10 of 20
Thread: abs sensor
    Mar 2011
    Glasgow
    Default abs sensor
    getting a fault code
    c0040-06 front right wheel speed sensor circuit open or low voltage
    does the abs sensor come separate or as part of the hub as a whole unit?
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    theycome as part of the hub as far as i no.
    scotland
    i had this , its the little 2 pin white plug thats corroded , I got one off ebay that was cut above the 2 pin connector and grafted it on and the taped it all up, cleared the faults now all ABS working fine without light on .
    hope this narrows it down a bit for you mate .
    Mar 2011
    Glasgow
    yeah i have been going through alot of deep water constantly thr last few weeks and now this happens which is leading me to believe corrosion
    What am I searching for on eBay ?
    scotland
    I just found someone breaking a vec and pm'd them for the abs harness but not the whole thing just the section from a few inches above the connector to the plug on the hub . There were a few not willin to cut it but it's a job replacing all the harness . Good luck :-)
    Mar 2011
    Glasgow
    just checked the sensor now and all plugs look nice clean and shiny
    checked the sensor resistance by unplugging it from the main loom (2 pins on voltmeter) and im getting infinite resistance (open circuit), is this the right way to test the sensor??
    Mar 2011
    Glasgow
    all the sensors are showing infinite resistance however fault is only coming up in relation to one sensor front right, can anyone assist in how i can test the sensor?
    Regular Member mattolly86's Avatar
    oxfordshire
    hiya pal, not sure if your aware but abs sensors work on a prinicble of a of halls generator, the wheel needs to be turning at a speed of about 5 mile an hour for the system to work, so idivindually checking the sensors wont help, my advice is trust the code and change the sensor on the wheel it tells you to.
    hope that helps
    oxfordshire
    forgot to mention its unlikely to be your abs ring, and if it is you will be able to see damage to it, check your air gap first (distance from sensore to abs ring), and security of speed sensor,
    Engine : 1.9 CDTi
    Disconnect the sensor and put a meter across the pins from the sensor and select volts on the meter.
    You should see a voltage as you turn the wheel going between about 0.5v and 4.5v.
    And the ABS is sealed inside the hub (As you can see below) so no sensor to see or check apart from any damage to the wires coming from the hub itself.
  1. Replies: 3
    Last Post: 13th August 2012, 22:25
  2. P0141-04 o2 sensor heater circuit open (bank 1 sensor 2)
    By Mark1892 in forum Engine & Drivetrain
    Last Post: 3rd August 2012, 09:19
  3. Fitting & Installation of ABS Harness & brake Help sensor sensor
    By Elahi_786 in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2012, 20:46
vectra c abs open circuit
coo40 vauxhall zafira abs light
insignia abs light on fault codes on all sensors
opel vectra c abs sensor plug
vectra c remove abs ring
vectra c abs loom
vectra c cleaning abs
vectra c wheel sensor symptoms
vectra c front abs ring
