Thread: Right my hid stopped working
    Jul 2011
    UK
    Year : 06
    Default Right my hid stopped working
    Imy driver side hid stopped working so took the bulb out changed bulb didn't work so put a normal bulb back in now I looked down were the ballest is (under headlight) and the bottom of it is white anyone know what that is couple month ago my passenger side ballest stopped working didnt get time to send back (hid direct) and put a old ballest in works great so does anyone know what the white could be like a powder when i rub finger on it so need to contact them and send them back
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Corrosion of the metal. Mine are like it too.
    wirral
    39 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    as above corrosion on the metal. and its probably stopped working due to condensation the circuit board, take it out unscrew it and dry ciruit board with a hairdryer and spray some wd40 on it. and its probably work again.
    Quote Originally Posted by CritchvxD View Post
    On the PCB?
    One sure way to knacker it completely. The WD40 will act as a conductor and short out the components.
    Regular Member Grimy's Avatar
    On the PCB?
    Not as far as I know. Wd40 is a water dispurser and is non conductive. We use it quite often at work to clean printing ink off all sorts of pcbs including high voltage drives with no trouble. Obviously we wipe off the excess, but the only thing to worry about with use on electrical components is the possible degrigation of wire insulation with frequent use
    From the solvent propelent, once that's evaporated your left with what's pretty much just fish oil protecting the surface from corosion.
    Jul 2011
    UK
    Year : 06
    That's what I thought about other box that been sat in room couple months and that still not work. When the lights come on the light just flicker and go off this mean its dead
    Jul 2011
    UK
    Year : 06
    Bump
    wirral
    39 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    On the PCB?
    Worked perfectly fine for me on both my ballasts after I had to drive through a mini river basically after the road had flooded
    Given time the residue left behind by the WD40 will attract dust and belly button fluff and that's when you might start to experience problems.
    Where I work, we get customers using some of our electronic equipment outdoors, and then they bring it back to us for repair. Prior to handing it over they say "we think it got wet, but we got it working again by giving it a squirt of WD40".
    Guess who has to clean up the PCBs with electronic cleaning solvent to remove all the crap left behind by the WD40 - yep, me and my colleagues.
    Jan 2010
    Liverpool
    I fitted HID's to mine and the drivers side ballast failed after roughly six months. I put it down to the fact they strobe occasionally. The drivers strobes more than the passengers side. (I really need to find out how to set the car to think it has HID's)
  1. Sub has stopped working
    By inchy1981 in forum Electrical & ICE (including SatNav)
    Last Post: 7th December 2012, 16:35
  2. Sat Nav Stopped Working
    By alhambra in forum Electrical & ICE (including SatNav)
    Last Post: 26th September 2012, 19:24
  3. DAB stopped working
    By sandman1001 in forum Electrical & ICE (including SatNav)
    Last Post: 8th February 2011, 22:27
  4. Fan stopped working
    By andyxedos in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd December 2009, 23:18
  5. Air Con stopped working
    By pvmoore in forum Vectra C / Signum Troubleshooting
    Last Post: 30th July 2009, 22:31
hid on vectra only 1 side working
