Results 1 to 10 of 11
Thread: Squeaking noise from Rear End
    Regular Member WeDesign's Avatar
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Default Squeaking noise from Rear End
    Recently had the rear springs replaced on my CDTi 150 which cured the "thud" noise I when ove bumps.
    I still have a squeaking noise, sounds like an old type pram squeaky noise (can't really explain it)
    Any ideas?
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Anybody??
    wirral
    49 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Anti roll bar bushes
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Quote Originally Posted by CritchvxD View Post
    Good Call, I was thinking them
    Regular Member ONEMINUTESILENCE's Avatar
    Jul 2010
    Skipton
    Check the boot opening struts also. I had banging & it turned out to be them! Cheap to fix as well.
    exeter
    shocks ?
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Had the car looked by two garages and reported no problem with my springs or shocks, they looked at anti roll bar bushes and appeared fine.
    I have since taken the polystyrene thingy that holds the jack and tools and also the plastic ring that is mounted under the spare wheel in the boot well.
    I shall report back on my findings.
    Any other suggestions forth coming on this?
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Still the squeaky noise exists
    The squeeky noise on mine was the nearside rear shock
    It had been inspected three times and was found to be working
    When it eventually failed nearly a year later, first leaking and then wallowing over a period of three days, and both rears were replaced the noise disappeared
    Sep 2009
    Audley STAFFS
    Quote Originally Posted by Sebastian B View Post
    dont it drive you nuts it does me,, only just started on my 04 i.8, its not long passed mot, rear springs all good, shocks seem to be working ok, thought it was the exhaust as the centre box bracket had broke and all the joints looked naffed so,, had a complete new system from the cat to the back 187 quid,,,, still squeaking
  1. Squeaking/odd noise
    By DaKemps in forum Suspension, Wheels & Brakes
    Last Post: 19th June 2012, 23:01
  2. Squeaking noise
    By beat275 in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2012, 11:04
  3. squeaking noise
    By deepak in forum Vectra C / Signum Car Chat
    Last Post: 16th August 2011, 17:20
  4. squeaking noise from the rear of the car
    By signum driver in forum Suspension, Wheels & Brakes
    Last Post: 24th March 2011, 21:19
  5. Another Squeaking Noise
    By Damian in forum Vectra C / Signum Car Chat
    Last Post: 16th July 2007, 07:54
vectra c squeaky rear suspension
squeak in rear suspension vectra c
vectra zc rear suspension squeak
vectra rear suspension squeak
