Just wondering if anybody could help me with this? I'vd just drove home from work and i've got a knocking noise when i turn the steering wheel. It's an 07 signum 3.0v6 cdti elite.
Turning at slow speed? Does it knock only with wheel in one direction or both?
poss strut top mounts
strut top bearings have dried up and are needing replaced
Just for starters check the pinch bolt on the joint/coupling that secures the column to the steering rack. It can be found down behind the engine. Easy enough to get at, just try and nip it up as they work loose.
Mick
It dose it when i turn the wheel both ways and when on stop and i turn the wheel.
as above check the joint thy known to work loose.
Thank Mick i'll have a look at that tomorrow when it's light.
Is it safe to drive to work in the morning? what do you guys think?
I personally wouldnt, i wouldnt wana do any more damage especially as its still un-diagnosed.
I drove mine for a while until I actually found the cause, it seemed solid enough and ok. As said though it's your choice really, and depends how far you drive as well.
Take care whatever you do.
Mick
