Results 1 to 10 of 15
Thread: Tools required for oil & filter change
    Liverpool
    Default Tools required for oil & filter change
    I am borrowing a hangar in work to do this out of the weather, but rather than taking all my tools, just want to take whats needed
    I am attempting an oil & filter change and also changing my fuel filter for the first time, i am quite confident at the DIY part of things, but never done this, i always end up bottling out and going to the garage instead lol
    Anyway as far as i can figure out im going to need a 32mm socket for oil filter, 13mm for oil sump and a flat blade screwdriver for fuel filter (why oh why cant they just settle for the good old in line filters?) anyway will i need owt else?
    Thanks for any help lads
    wirral
    39 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Plenty of rags for cleaning up.
    Some fresh fuel/ fuelncleaner to top filter housing up to aid starting.
    Regular Member Sigmacca's Avatar
    Jun 2011
    Skegness
    Thermals and a flask of tea and AA membership!!
    Jun 2011
    Skegness
    washing up bowl to catch the old oil, car jack so you have enough room under it, funnel is a good idea, disposable gloves,
    Its not hard to do, once oil had drained I like to pour about half a litre in the top and let that run straight through
    Good Luck!!
    Aug 2010
    Leeds
    Book a night out in the pub afterwards to wind down.
    Ely, Cambridgeshire
    60 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    I'm pretty sure if it's a 1.9 150 diesel as per your profile you'll need a 36mm socket not a 32mm one. Don't forget to pick up a replacement sump plug washer from the dealers.
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    New sump plug lOl
    Aug 2010
    Derbyshire
    Quote Originally Posted by Ian-Highlander View Post
    Definately a 32mm socket is needed for filter removal on a CDTi 150.
    I have both 36mm & 32mm sockets, 36mm I used on my Omega TD filter.
    BTW I never got a new sump plug, reused the old one.
    Mick
    Aug 2010
    Derbyshire
    Oh and if you don't have access to a ramp/pit, so working off the floor you will need to remove the complete engine undertray. There's not enough room to drop the service flap when jacked up, so easier to remove the whole thing. You'll also get easier access to the oil filter as well. You'll also need a light to see where that hard to get at filter is.
    Hope it's not put you off, done once it's easier next time.
    Mick
    Jan 2008
    Lincs
    Vehicle : Vectra C Hatch
    Trim : Exclusive Plus Pack
    Engine : 1.9 CDTi Z19DTH
    Year : 57
    Mileage : 100k+
    I'd get a new sump plug (and washer) in case you mash up the old one which they have a tendency to do, mine did even with a six-sided socket. I needed a hammer and cold chisel on the flange to get it started.
    As for the service flap, I removed the 'hinge' tape at the front and riveted an ally plate on to act as a lip - now it is a removable panel.
  1. 1.9 CDi design (150 Fuel Filter Removal Tools
    By AdamNEUK in forum Vectra C / Signum Troubleshooting
    Last Post: 16th December 2012, 10:58
  2. could someone confirm oil change tools 3.2
    By TimTay in forum Engine & Drivetrain
    Last Post: 11th August 2011, 15:59
  3. Signum 3.0 V6 cdti oil change. Special tool required for filter?
    By onlymeagain in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2011, 09:35
  4. Tools required for 2.0DTI Plug Change?
    By Thom in forum Engine & Drivetrain
    Last Post: 14th December 2010, 20:16
  5. Rear shocks - tools required???
    By mr.c72 in forum Suspension, Wheels & Brakes
    Last Post: 13th May 2010, 13:50
tools required for vectra c oil change
vectra c 2.0 dti what tool for sump plug
