Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: Parrot Fitted...
    Regular Member weverall's Avatar
    Littleport, Ely, Cambs
    Default Parrot Fitted...
    Finally took the plung and fitted my new ck3100 parrot into the car..
    after the pain in the backend of getting the loom and everything sorted behind the radio... it all sorted.
    then came the mic problem. couldnt find a torx screwdriver. so was annoyed about where to put it...
    then found one, and bang removed my glovebox. only to find a fully fitte BURY kit.. so removed that and fed my mic through, up the pillar and into stealth bit.
    overall im proud of it, but the only thing is where the HUD is sitting, i cant fit the blanking panel back in so its sitting open?
    any suggestions??
    Dave
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    i fitted mine to the top of the vents.
    I thought about that, but figured that was a bit too high up the dash for me...
    now trying to figure out whether i risk dremelling the blanking plate to make it look better. or just leave it.
    Ely, Cambridgeshire
    60 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Bring it out so the cable is underneath the silver strip under the vents. Remove the strip and vents and feed the cable out there, there's enough gaps and room for a cable to fit with everything put back in place (I used to run a second car cradle the same way when I had to use two mobiles).
    What Ian said that's how I did mine
    Sent from my iPhone using My thumb
    How do i go about removing the vents?
    i had a look at it earlier, but couldnt work out whether they popped out and where best to pop them from?
    and also the silver strip... id it just a case of lever off with a screwdrive or something?
    Dave
    Jan 2008
    Lincs
    Vehicle : Vectra C Hatch
    Trim : Exclusive Plus Pack
    Engine : 1.9 CDTi Z19DTH
    Year : 57
    Mileage : 100k+
    How have you attached the display to the dash?
    Why not adapt the switch blank to make the wire fit and even attach the the display to the blank too. It's pretty cheap to get a new switch blank if you come to remove the display later.
    Engine : 1.9 CDTi
    Quote Originally Posted by weverall View Post
    Dave
    Open the glove box and feel under the silver trim.
    You should feel a gap/edge you can get you fingers onto and pull it hard. First time I did it I thought it was going to break as you need to pull it quite hard.
    Quote Originally Posted by vxvirgin View Post
    This is what i was thinking, dremelling the bottom of the blank, so the wire slips in, then have the Display attached to that instead of the dash..
    gunna give it a go i think, can always a get a replacement blank
    Ely, Cambridgeshire
    60 Post(s)
    Year : 2010
    Dave
    Open glovebox to get your hand under the silver strip and it just pulls off. Once that's off there's four torx screws and the vent assembly comes out. 20 second job.
  1. Parrot Mki9200 Fitted :D
    By Kev_G in forum Electrical & ICE (including SatNav)
    Last Post: 16th May 2011, 12:15
  2. New parrot fitted
    By lochgilp in forum Electrical & ICE (including SatNav)
    Last Post: 24th December 2007, 15:52
  3. Fitted Parrot CK3100
    By lexicon in forum Electrical & ICE (including SatNav)
    Last Post: 8th July 2007, 21:46
  4. Parrot 3200 being fitted now.
    By sgmiller in forum Electrical & ICE (including SatNav)
    Last Post: 2nd July 2007, 19:19
  5. Fitted Parrot 3200 Kit
    By DesignforLife in forum Electrical & ICE (including SatNav)
    Last Post: 28th January 2007, 18:36
