Results 1 to 10 of 11
Thread: Exhaust Bracket Weld?
    Regular Member chrisf70's Avatar
    Mar 2007
    Cambridgeshire
    Default Exhaust Bracket Weld?
    Morning all, start my new job this morning and notice yesterday evening that the mounting bracket on the right hand rear box on my 2.2 Direct Signum exhaust had corroded through and failed. So box was hanging down by 6inches.
    Have patched up with wire to get me to work today, but question is, can this be welded back on as exhaust is fine apart from this?
    Also who to go to; independent garage or exhaust fitters? If it is possible what do people think price would be?
    Thanks.
    morecambe
    32 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Yep I had the same problem mate all my hangers down the middle had snapped but make shore u get it sorted ASAP because my flexi joint broke because there was to much movement
    Durham
    I had the same problem, My vectra C failed an MOT at Kwikfit and they wanted to replace the entire exhaust. I took it to a back street garage and they welded the brackets back on for £20.
    Regular Member CH-VECTRA-ELITE's Avatar
    Frimley
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 140000
    the brackets on my exhaust have started to rust and the right one does drop, was thinking of taking mine to kwikfit but i bet they'll try and pull a fast one.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    All my brackets are gone .. all new made op with proper welding, and new bracket made out of 1 cm think round steel.
    Regular Member marshy200's Avatar
    Apr 2011
    Barnsley
    I am a welder by trade and exhaust boxes can be welded, no probs.
    In fact, did mine a couple of weeks ago.
    I fit a new S/S tail pipe and dropped the box a bit.
    You see, the mig welder makes life very easy...
    Engine : 1.9 CDTi
    I just used some new exhaust 'U' clamps and welded some bar onto them and bent them to suit.
    Mar 2007
    Cambridgeshire
    Cheers lads, will get it down the garage this week.
    Frimley
    Mileage : 140000
    Went to kwik fit yesterday and the guy replaced both my brackets for £10 cash. I was very surprised, thought they were going to try it on saying I needed stuff replaced but he told me for a stainless steal system it been made very well.
    Regular Member kentish_bloke's Avatar
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    I had a similar problem just before my MOT back in July. Got 1 of the guys at the workshop where i'm based to weld the hangers back on. Sailed through the MOT & the repair only cost me a tenner!
  1. can i weld up my dmf ???
    By Turbomanrony in forum Engine & Drivetrain
    Last Post: 15th December 2011, 21:02
  2. Exhaust.braided flex joint section.bracket broken.help.
    By Dobs in forum Engine & Drivetrain
    Last Post: 13th March 2011, 15:03
  3. what car tax bracket
    By kns in forum Vectra C / Signum Car Chat
    Last Post: 13th March 2008, 20:58
  4. OK. Holts Rad Weld, or Bars Leaks?
    By Ste in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2008, 21:25
  5. Can you weld Stainless Steel???
    By BigMan in forum Vectra C / Signum Car Chat
    Last Post: 10th August 2007, 23:10
vectra c exhaust bracket
vauxhall vectra welded exhaust bracket
is my vauxhall vectra exhaust bracket welded on
