Results 1 to 10 of 15
Thread: heater matrix pipes both cold HELP!!!
    Dec 2011
    mansfield
    Default heater matrix pipes both cold HELP!!!
    Ive just replaced the thermostat on my vectra 1.9cdti 120 stripped the egr and thb off cleaned and replaced the gaskets fitted fiat egr plate and re assembled car now starts first time runs great but to my horror another problem has rised heater still only blowing cold and the 2 pipes that go into heater matrix through the bulk head are cold at the top and hot near the thermostat have i got a massive air lock? or is my heater matrix had it ? ive also noticed the temp on the gauge goes from 80 upto 90 and back down but never goes over 90 or below 80 is this a sign of a air lock? im not to clever when it comes to heater problems ive seen posts where one pipe is hot and one cold but both are cold does anyone know what the problem is and how to fix as im freezin in the car lol
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Did you bleed the air out the system by removing the screw at the top, front metal coolant pipe? (replace it when coolant flows out, free of bubbles)
    Dec 2011
    mansfield
    yes did that while engine was running and upto tempreture does the water flow through the matrix constantly or just when u have the heater on hot ?
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Get the eninge running, remove expansion cap. Squeeze the bottom hose and pump it a few times.
    Once hot turn heaters on to full got inside car
    Pump the hose again should release any trapped air
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Try removing the bleed screw once more, just in case (heater temp must be turned to max, with motor on speed 1), then take the car for a good drive to get any remaining air shifted, keeping the heater on hot
    Dec 2011
    mansfield
    thanks for the help will try tomorrow and see if this helps im also thinking the heater controll panel might be broke as when u turn from cold to hot there is no change in blower speed and nothing seems to make any noise like its opening the flaps everythin else works but im not sure if the heater knob is
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    When you turn from cold to hot, make sure motor is spinning on speed 1, and listen closely for the flaps moving
    If not, pop out the panel and check the connection on the back
    Dec 2011
    mansfield
    thanks for that pal u bin a big help will let u know how it goes fingers crossed lol
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by all vaux View Post
    No probs mate. That's what these forums are for
    Dec 2011
    mansfield
    time for a update lol changed the heator resistor today so it blows on 1,2,3,4, now while i had the glovebox out i turned the heater knob to see if it opened the flap and it didnt so i pulled off the control arm and opened the flap manualy hopein that would give me some hot air but no i still only got cool air ive bled the system again following instructions from tony but had no effect im starting to think the matrix has a massive air lock or blocked i looked through my haynes manual and its says to take off the left hose that goes to the matrix and let the matrix drain and then try again has anyone tried this ? if that dont work my only other thought is to take off both hoses and stick a hose pipe in the right hose and blow it through is this right?
  1. heater matrix
    By strothrc in forum Engine & Drivetrain
    Last Post: 13th March 2012, 13:31
  2. Heater matrix!
    By SUBEK in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd December 2011, 15:43
  3. replacing heater matrix
    By :LeeR in forum Engine & Drivetrain
    Last Post: 5th October 2011, 11:42
  4. Heater matrix now done
    By adfrodsham in forum Bodywork & Interior
    Last Post: 24th February 2010, 23:00
  5. Just Changed Heater Matrix...
    By sophos9 in forum Vectra C / Signum Car Chat
    Last Post: 19th August 2008, 15:04
https:www.vectra-c.comforumshowthread.php152317-heater-matrix-pipes-both-cold-HELP!!!
how to remove an airlock from heater matrix vectra
corsa heater matrix hoses cold
astra heater mateix top cold bottom warm
both pipes to heater matrix are hot
vectra c leaking matrix pipes
vectra c heater matrix water pipes
vauxhall matrix pipes cold
vectra matrix what why does the water flow
heater matrix. vauxhall one pipe out the other cold
heater matrix pipes cold on combo
vectra c matrix
1.9 cdti heater matrix pipes connect to
two hoses top ofvheater matrix one hot one cold
matrix pipes cold vauxhall
Zafira b heater matrix pipes cold
both pipes to heater matrix cold
how to remove airlock from heater matrix vectra
do heater matrix pipes get hot
hoses cold heatdr matrix
vauxhall astra heater matrix hose
corsa c heater matrix pipes cold
vauxhall omega heater matrix blocked
