Results 1 to 10 of 13
Thread: 1.9 Complete Electrical Fault
    Mar 2011
    Bedfordshire
    Default 1.9 Complete Electrical Fault
    Hi all,
    I hope you can help me locate this fault and thank you for reading.
    Today i was driving home and when i came to a roundabout the dash lights and radio would fade and then go out.
    After the roundabout the dash electrics would come back displaying airbag and ABS warning. a few seconds more and then they would go out.
    When i got home (1 mile) i would turn the ignituon on and run the fan at 2. if i raised the fan speed the dash would fail again.
    while this is happening i would hear a click from the passenger foot well. This click reminds me of a relay click.
    i have had a look at the internal fuse box and there does not seem to be any relays.
    any ideas i can look at to resolve this issue.
    thank you in advance
    Russell
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    I will go out on a limb m8 and say alternator. Have it checked.
    Insignia VX-Line Nav CDTI 170.
    wirral
    32 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Sounds like alternator on way out
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    ^^^ What they said
    Glasgow
    As above that's the alternator failing.
    Mar 2011
    Bedfordshire
    Default alternator then
    From this i assume that it is the alternator. :-) What is the chance that it could just be the Battery? worth replacing / testing?
    Just been out. the car wont start now so it looks like it is one or the other.
    Russell
    Last edited by DamnManCannon; 18th December 2011 at 20:43. Reason: forgot someting
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Start the engine and put a multi meter over the battery terminals. Voltage should be at least 14.2v (turn all electrical items off, lights, etc). If any less, then it's your alternator
    Mar 2011
    Bedfordshire
    Default Reply
    Thanks to you all
    Jun 2007
    Scotland
    Vehicle : Insignia
    Year : 2015
    Mileage : 27000
    Quote Originally Posted by DamnManCannon View Post
    Russell
    Batteries usually only affect starting. When the engine is running it uses the alternator. Alternators can also be the secondary cause of bad starting/failure to start if they are failing to charge the battery.
    scottish region
    I would also say altenator won't start as battery is not charging so no juice left in it to start change altenator and battery will charge back up again
  1. electrical fault please help
    By adamuk14 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd February 2012, 01:26
  2. 1.9 CDTI complete electrical fail!
    By orangepeeleo in forum Electrical & ICE (including SatNav)
    Last Post: 22nd January 2011, 18:05
  3. Help (Electrical Fault)
    By Badger59 in forum Vectra C / Signum Car Chat
    Last Post: 30th October 2010, 19:54
  4. Complete electrical failure
    By iRocco in forum Electrical & ICE (including SatNav)
    Last Post: 23rd March 2010, 19:32
  5. electrical fault
    By :LeeR: in forum Electrical & ICE (including SatNav)
    Last Post: 24th April 2008, 18:14
