Results 1 to 10 of 13
Thread: VXR Exhaust help!!!
    Regular Member benholden2010's Avatar
    Oct 2010
    middlesbrough
    Default VXR Exhaust help!!!
    Picked the VXR exhaust up that I won on eBay today and set about fitting it this afternoon
    From what I'd read on here it should of been a perfect fit, it isn't!
    Problem is that the flexible-pipe exhaust is a smaller diameter than the VXR centre section,(by about 10mm) so what do I need to fix this?
    Couldn't be arsed takin it back off as it was getting dark so I'll try and get some measurements tomorrow, unless anyone knows the original flexipipe diameter and VXR exhaust diameter?
    Cars sounding like a tank atm so need this sorting asap if anyone has any info/ideas it'll be much appreciated
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    You need to fit a reducer to the pipe to reduce it down to the right size for your one. The VXR exhaust is a bigger bore than a 2.0T's one.
    Oct 2010
    middlesbrough
    Cheers Ian, will I get one of these from local car shop (halfords, eurocarparts etc..) or is it a special size part?
    Does anyone know what size reducer I will need? Had a google but not throwing anything up....
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    The 2.0T is usually a 2.25" pipe not sure how much bigger the VXR one is. I'd imagine any exhaust place should be able to supply a reducer pipe.
    Oct 2010
    middlesbrough
    Well I can't find the vxr bore size anywhere on the net so looks like I'll have to take it off and measure tomorrow:@
    Fingers crossed all will be sorted tomorrow....
    Blantyre
    I think the bore is 3 inch, when I got mine fitted I got a pipe made up as I couldn't find a reducer :-(
    Regular Member chuckleuk's Avatar
    Jul 2010
    Swadlincote
    The vxr exhaust is 2.5 inch I had one fitted to my old 2.0 turbo
    Oct 2010
    middlesbrough
    2.5 inch at the centre pipe? So by the looks of it I need a 2.25" to 2.5" reducer...could of sworn they was a bigger gap than that
    Jul 2010
    Swadlincote
    yeah im sure its 2.5 inch at centre pipe just get a tape measure on it to make sure, when i had mine fitted went to an exhaust place and they made a reducer and welded in all in place
    Oct 2010
    middlesbrough
    Cheers fella, I'll have a look tomorrow
  1. Exhaust hanger broken /rotted from exhaust.please help.
    By Dobs in forum Engine & Drivetrain
    Last Post: 25th January 2012, 21:06
  2. Duel exhaust - where to get a right hand exhaust heat shield
    By Innes in forum Bodywork & Interior
    Last Post: 29th November 2011, 00:47
  3. Fitting Dual Exhaust on single exhaust 2.2 sri
    By sdnatlst in forum Petrol Engine related
    Last Post: 1st February 2010, 10:49
  4. Where to buy oval exhaust tail pipes for signum exhaust
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2008, 17:16
  5. Replies: 7
    Last Post: 22nd August 2007, 21:16
