Thread: Adjusting Handbreak
    Mar 2011
    South Normanton, Debryshire
    Default Adjusting Handbreak
    Hey Guys & Gals,
    Yesterday i had my rear pads changed as one was down to the metal ooppss.
    Anyway after having them changed when i got in the car a few hours later i noticed the hand brake pulls up a lot higher than normal. Is it easy to adjust? as im guessing this is what needs doing? would it be something an idiot like me could do or am i better off getting a professional to do it?
    Cheers Alan.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    The handbrake is self-adjusting. With time, it will pull up less clicks. Mine came up about 8 clicks when I done the rear brakes, and was about 4 clicks after a couple of weeks
    Regular Member benny's Avatar
    Feb 2006
    dudley
    my hand breaks aint adjustable ...lol.........he he ......... were the pads fitted correctly ? pedal pumped up and driven before the hand brake beeing put on ....if the hand brake was put on early or before the pedal was pumped up it wont be any good ......if it does need adjustment its not a simple task involves removeing the arm rest between the seats ....and moveing some adjuster parts on the back of the leaver ...
    wirral
    58 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Pump brake pedal till solid, keep it applied and hand brake, should reset nit then.
    But does feel wired for a few days.
    I justnkept going over that same method every time. Sopped the car for few. Days and it sorted it
    Mar 2011
    Ok cheers guys the pedal was pumped first so hopefully it will sort it's self out lol
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by Alank View Post
    Give it a few days. Should sort itself out
    ---Sent from my iPhone 4 using Tapatalk
  1. handbreak question.....
    By vectra gsi 3.2 in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2012, 02:13
  2. Adjusting coilovers
    By Friel in forum Handling & Braking
    Last Post: 18th January 2011, 11:52
  3. Handbreak cable reset?
    By stryker99 in forum Suspension, Wheels & Brakes
    Last Post: 6th July 2010, 11:33
  4. Need to replace handbreak cables
    Last Post: 4th July 2010, 15:03
  5. adjusting headlights
    By vectragsi3.2 in forum Vectra C / Signum Car Chat
    Last Post: 15th December 2008, 20:29
