Thread: Tailgate wiring harness
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Default Tailgate wiring harness
    Hi all
    Has anyone had to remove the tailgate wiring harness. I need to change my tailgate as it was damaged and i have a replacement. It looks like there are no connecters in the har ness and that it connects directly to the REC and that i will have to thread the harness backwards through the tailgate. Can someone confirm this please.
    Oh and its a hatchback.
    Colin
    Wirral / ellesmere port
    12 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    hi m8
    the tailgate harness runs down to the rec that can be un plugged from there
    but im sure theres also connectors behind the tailgate trim in the top corner
    as it comes into the tailgate from the bodyside.
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Thanks for the reply Andy.
    I had a quick look yesterday and couldn't see any connecters but will have another look during the week.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    yes there are connectores and you will have to take the one apart to get it through....
    But it all runs to the REC.. no where else.
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Thanks Kenp
    It appears the connector is near wiper loom didn't look down that far but now i know it will make the job easier.
    Engine : 2.2 Direct
    Sorry i misread your post... its 1 harness.. and you will have to feed it from the car to the tailgate to get it out.. (cant get it the other way) also note that you will have to remove the pipe from the rear screen wash.
    Most clips will break when you remove it.. as you just cant get to them when the rear screen is mounted to the tailgate.
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Hi all
    Finally replaced my tailgate yesterday.
    Once the trim has been removed there are two multi-pin connectors near the
    wiper motor. Unclip these and you can feed them back up to the top. On the replacement tailgate i fed some wire through then taped connectors to this.
    A bit fiddily but came through ok. Very pleased with the outcome colour match is superb it looks like the original.
  1. Do I need a Wiring Harness?
    By weidass in forum Electrical & ICE (including SatNav)
    Last Post: 4th September 2012, 22:17
  2. vectra c wiring harness
    By viper8 in forum Electrical & ICE (including SatNav)
    Last Post: 27th March 2011, 15:29
  3. How do i know which wiring harness i need?
    By caigey in forum Electrical & ICE (including SatNav)
    Last Post: 28th July 2009, 21:49
vectra c boot wiring
vectra c tailgate wiring
vectra c tailgate wire disconnect
tailgate wiring diagram signum
