Results 1 to 10 of 24
Thread: Another aircon question
    Regular Member 111's Avatar
    Stockton-on-Tees
    Default Another aircon question
    Can anyone tell me if there is a way to test the aircon is working in this low temp weather, I had it topped up 3 months ago with 173g recovered, now it doestn't work, I thought it would still work if recirc or the screen clear was used, is this the case? if so mine must need a new condenser
    Regular Member crispy007's Avatar
    Oct 2010
    lincs
    I had this problem a bit ago turned out it needed a new condenser it has now been fitted (under Warranty) and works fine
    The air con should not operate when the ambient temperature is below 5'C
    What temperature is on the display?
    Stockton-on-Tees
    It's 2.5oC on the display, but I would have thought it would work if the air re-circulation or screen clear was used! as every other car i have had does, even if the outside temp is below 5, otherwise the car would steam up while trying to get the inside warm on a cold morning.
    No, the air con should not be operating
    The switch can be in the ON position but the system will be OFF
    You can test this by turning the heater motor to the zero / OFF position
    When the air con is operating the system will remain with motor in position 1
    When the air con system has turned itself off the motor will also be off
    Stockton-on-Tees
    So what's the point of having air recirculation on a cold morning to warn the inside of the car up as you wont be able to see out of the windows because they will just mist up? it just makes it pointless/useless, that's the part I can't get my head round. + you are told to use it at least once a week to keep the system lubricated, how can you do that in the winter months. if it wont work on at least one setting?
    That's just the way it is
    On a cold morning use the front heated windscreen option, that is much quicker than waiting for the engine to warm up and using the air conditioning (when the ambient temperature allows the air con to operate)
    Regular Member kns's Avatar
    Northampton
    What front heated window screen ?
    My 2006 SRI does not have a front heated screen as far as I am aware or am I missing something ?
    Stockton-on-Tees
    Quote Originally Posted by kns View Post
    Not heated screen, but the button that puts all the air to the screen & should turn the aircon on.
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Its only the cooling part of the air conditioning system that stops working in low temperatures, the system will still work perfectly well as a dehumidifier in all conditions.
  1. another aircon question
    By kirky2k4 in forum Vectra C / Signum Car Chat
    Last Post: 11th April 2011, 01:38
  2. Sorry but yet another aircon question
    By john1 in forum Vectra C / Signum Car Chat
    Last Post: 29th June 2010, 22:29
  3. Question about aircon
    By Ralphwells1967 in forum Vectra C / Signum Car Chat
    Last Post: 28th June 2010, 16:23
  4. aircon question
    By monty2000 in forum Vectra C / Signum Troubleshooting
    Last Post: 25th June 2010, 13:49
  5. Sorry Another Aircon Question
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 15th May 2008, 11:14
